Betcha haven't broken this....
Old 02-05-2005, 03:12 PM
okidoc's Avatar
The fan bracket for the 3.0. If you have replaced the timing belt/wp/hg on the 3vze you know what I mean. The bearings gave out and let the fan smack the rad. Can you replace/machine new bushings, is there a rebuild kit or do you buy a whole new unit. I will try to post a pic when I can.
Thanks for the help.
Dave
Old 02-05-2005, 03:32 PM
Guest
Yoter's Avatar
Dave
pics?
Old 02-05-2005, 03:39 PM
dwh91102's Avatar
Yes I broke this part about a 2 yrs ago on my truck...if you want a real laugh call the stealership they want about $675 for this part, I paid about 100 for mine from a junk yard, you can get one from ebay for $70 if this is what you speak of
Old 02-05-2005, 04:09 PM
okidoc's Avatar
I just tried to take some pics but for some reason I can't download them to my comp. I will try to describe the part better. I need info on the fan carrier. This is the cast aluminum piece that holds the fan onto the engine via the fan shaft. It also holds the center pulleys in place that are on the shaft. If you are looking at the front of the engine these are the pulleys where the p/s and alt belts meet. It is not the water pump which I initially thought it was. It is described as the fan pulley bracket by chiltons in step 11 timing belt install.
Thanks again for any info. I have never seen anyone complain of this and any info or leads on parts would be great. If nobody has any info I'm off to the junk yard tomorrow.
dwh91102's Avatar
cant you see my last post?
Old 02-05-2005, 04:27 PM
okidoc's Avatar
Yeah I just saw it. While I was taking pics I got signed off. Dial Up . Net zero sucks.
Thanks I found a couple websites that sell them for 140.00 I might go that route. Nothing on ebay.
Thanks for understanding. What an annoying, poorly designed setup. It looks like they tried to use as many moving parts as possible. Mine let go in parking lot so there wasn't too much other damage, I guess that's a bright side.
Dave
Old 02-05-2005, 04:32 PM
dwh91102's Avatar
theres tons of them on ebay type in "toyota truck fan" scroll down a few and theres a bunch of them, for real if you want a good laugh call the stealership monday and ask for there price
Old 02-05-2005, 04:40 PM
okidoc's Avatar
Got em. Thanks I was searching for "fan carrier", "false water pump", and everything else. Guess I was way off. Thanks again
Old 02-05-2005, 04:45 PM
dwh91102's Avatar
no problem, if your not in a extreme hurry, I would probally order one of ebay as there new aftermarket part, as to used from a junkyard, and as i said earlier the junkyard knew when i called what the stealerships charge for the part, but if its your only ride the junk yard one should be ok I've had no problems out of mine
RickyD
10-02-2015 07:53 AM
90YotaPU
09-21-2015 11:59 PM
punks_is_4x4
09-19-2015 05:52 AM
themightykhoner
09-18-2015 02:28 AM
Boomer8404
09-10-2015 09:01 AM
Quick Reply: Betcha haven't broken this....
