| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#26 (permalink) | |||||
#27 (permalink) |
Here's a good link on relay basics:
http://www.bcae1.com/relays.htm
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. |
#28 (permalink) |
Wiring the relays is quite easy.
First where you put it is not a big deal, i put it in the car due to that way when i wash my engine they won't get wet. And it is easy to wire it in the car, you just have to get down in the floor board of the drivers side lol. But either way will work. Now for how to wire it up. Read those links. I used the cigeret lighter wire as the ingnition switched power source. Tap that wire and then run it to the relays. Ground the other side of the cold side. Then on the hot side connect the 12v+ to one and the wire to the heaters to the other. Those links will explain where the wires go. As for your question, i would just use the cigeret lighter and the igntion wire switch. Works perfect for me.
__________________
Just call me TA 2000 Toyota 4runner Limited 3.4l V6 Auto SUPERCHARGED, URD 7th, 2.2 pulley, Doug Thorley Headers - My truck All the Mods that can be done to 3rd Gens Thread My thoughts on Gun control summed up quite nice: “Gun control runs aground on this simple fact: people who would use guns to break laws would also break laws to use guns” |
#29 (permalink) |
wired it to the cigarette lighter from under the hood. i just kinda wrapped it around the positive lead from the back of the right 12v jack. its a bit sketchy i gotta admit.. but i didnt wanna F&*(^ anything up. i figure it can only start a fire while im in the car.. and i like those odds.
sk thanks again for the help fellas |
#30 (permalink) | |
Quote:
__________________
| Tags |
| 08, 4runner, amp, amplifier, auto, car, connects, drill, firewall, install, passthrough, place, terminal, toyota, wire |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Firewall Grommet | iscool007 | 86-95 Trucks & 4Runners | 8 | 04-26-2007 06:38 PM |
| Cracked Firewall | Jmunk | Maintenance & Repair Archives | 1 | 10-24-2005 11:48 AM |
| Best way to get through firewall? | NMcruser | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 03-07-2004 07:54 PM |
| Disabling XP firewall? | Toyota Punk | Off Topic Talk | 3 | 07-16-2003 12:31 AM |
