Best oil for high mileage - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 05-29-2004, 08:18 PM   #1
I was wondering what every body thought was the best oil for high miles. Im running Pennzoil 10w30 high mileage , but I want to change. My truck has 150,000 miles.
red 59 is offline   Reply With Quote
Old 05-29-2004, 08:40 PM   #2
Brendan's Avatar
my neighbor has an 81 2wd toyota with over 400,000kms and he's using castrol 20w50.
Brendan is offline   Reply With Quote
Old 05-29-2004, 09:52 PM   #3
kford's Avatar
i'm not sure the high mileage is worth it. I use mobil 1 w/ 266k
i think high mileage is no different.
kford is offline   Reply With Quote
Old 05-29-2004, 09:55 PM   #4
SolidDigital's Avatar
not much of a fan of the high mileage oil. it's just a little thicker than the others and has some seal swelling junk in it. if I ever did use it though, I'd prolly get it in valvoline
SolidDigital is offline   Reply With Quote
Old 05-29-2004, 10:29 PM   #5
humanoid's Avatar
Red, just go with a quality synth and you and your rig should be good to go.
humanoid is offline   Reply With Quote
Old 05-30-2004, 12:27 AM   #6
Midnight Rider's Avatar
I've used Shell Rotella 15w30 in my truck since I bought it. It had 220,000 on the clock when I bought her...
Chuck
Midnight Rider is offline   Reply With Quote
Old 05-30-2004, 02:21 AM   #7
Why the change? Stick with what has been workin for ya.
Stock02 is offline   Reply With Quote
Old 05-31-2004, 06:46 PM   #8
bike4miles's Avatar
All my mechanic friends have always told me to stay away from penzoil becase they said it "gunks up your engine". They allso say that the high milage stuff can oversofen your seals if you use it all the time. I just run 10w40 instead of 10w30 of a high priced sinthetic and call it good.
bike4miles is offline   Reply With Quote
Old 05-31-2004, 07:12 PM   #9
keisur's Avatar
I just use the Castrol High Mileage oil.
keisur is offline   Reply With Quote
Old 06-01-2004, 03:20 PM   #10
Quote:
I would go with the Castrol HMO, or the Mobil HMO
toyotanut3717 is offline   Reply With Quote
Old 06-01-2004, 03:28 PM   #11
seaflea's Avatar
I have used castrol 10w 40 for 12 years and havent had a problem.
I recently switched to castrol high mileage. I only have a couple hundred miles with it, but it seems to be fine. I guess I'll find out in the long run.
seaflea is offline   Reply With Quote
Old 06-01-2004, 03:45 PM   #12
Are you having some specific problem you are trying to correct? If not there is no need for that marketing hype oil.
The best oil you can use in any engine, any mileage is AMSOIL. It has the max amount of benificial additives. There is nothing out on the market that can touch it. They have been making sure of that since 1972.
www.GadgetOnline.com/AMSOIL.htm
Gadget
Gadget is offline   Reply With Quote
Old 06-01-2004, 04:27 PM   #13
My99's Avatar
Quote:
Chuck
Uhh.. I use this in my diesel lawn tractor. I didn't know it was for gas motors too.. I guess it works!
My99 is offline   Reply With Quote
Old 06-01-2004, 04:38 PM   #14
Rotella is a Diesel engine oil.
You can run a Diesel engine oil in a gas engine, but you should not run a gas engine oil in a Diesel.
Gadget
Old 06-01-2004, 06:28 PM   #15
I wanted to quote both of Gadget's posts and agree, but since you can only do one I just typed this instead...
High mileage oils are a bunch of marketing hype, just like the 3000 mile oil change interval that has been perpetuated by the quick lube industry and their desire to increase their bottom line.
Synthetics aren't cost-effective unless you increase the drain intervals -- just expensive insurance. However, AMSOIL does in fact save you money at their recommended intervals. I ran the same oil in my Tundra for over 2 years without a drain. I tested it and changed the filters and the results kept coming back that it was good for continued use so I kept running it. And in the process I used different labs so I'm confident all was on the up and up.
Bottom line: use what you are comfortable with and change it at the recommended interval provided. You'll note that few oils offer a recommended drain interval, in hopes you will drain early and buy more...
~ Fred
RagerXS is offline   Reply With Quote
Old 06-01-2004, 06:28 PM   #16
Victor's Avatar
I use Mobil1 0w40. I used to use 5w30 but oil pressure seemed low at idle with the A/C on.
Victor is offline   Reply With Quote
Old 06-01-2004, 07:47 PM   #17
keisur's Avatar
Gadget
Uhh, well, it is available in my local stores here. I'm not into paying out the hole for oil and castrol has always been fine for me. I don't regularily send my oil in to get those tests done so it really makes no difference to me. oil is oil to me as long as it is changed at the recommended mileages. Note that I said, "for me" so I'm not looking for an argument here. I also was not talking about synthetic since I don't run that.
Old 06-02-2004, 12:09 AM   #18
Castrol for life
slimtim is offline   Reply With Quote
Old 06-02-2004, 04:47 AM   #19
Guest
Quote:
Yep, it's for gasoline engines as well. Has the current S ratings. It's a very good oil.
foxtrapper is offline   Reply With Quote
20R Break in- Really High Oil Pressure calderp Engine Swaps 2 08-16-2016 06:15 PM
*SOLD* 1991 Toyota Pickup DLX 4x4 5 speed 165k, fresh motor,lifted,clean! $6150 GreatLakesGuy The Classifieds GraveYard 8 09-04-2015 10:27 AM
Found in my oil pan irritech 95.5-2004 Tacomas & 96-2002 4Runners 3 07-27-2015 06:15 PM
HiGH oil pressure breaking in 20R calderp Pre 84 Trucks 8 07-27-2015 10:58 AM
Looking for help with high RPM redghost.308 California SoCal 0 07-16-2015 08:46 AM
Tags
150000, casrol, change, high, interval, landcruiser, milage, mile, mileage, oil, run, tacoma, toyota, toyotas, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
