Best Lift Set up
Old 04-04-2004, 10:41 PM
AxleIke's Avatar
Best Lift Set up
I was wondering people's opinions on lifts for late 80's vintage 4 runners. I have an 87, and i've installed some aftermarket shackles to get rid of the low back end, but i'd like to get the whole car up about 2 inches. Was wondering if people had ideas and or experience with lifts to get good quality for cheap.
Old 04-05-2004, 06:58 AM
Away
Dr. Zhivago's Avatar
Cheap = Body Lift
Hope this helps.
G
Old 04-05-2004, 09:01 AM
Flygtenstein's Avatar
Not sure about yours, but my runner gets pissed when I call it a car.
Roger Brown is the place for bodylifts.
Ball joint spacers, add-a-leafs and other options work in the rear.
Old 04-05-2004, 11:34 AM
Fink's Avatar
Yeah definately go Roger Brown...I'll be doing that as soon as I finish paying off the debt that I'm in now.
And yeah, my runner tends to hesitate and sometimes backfires when the word "car" is mentioned around her...
Fink
Old 04-05-2004, 01:32 PM
AxleIke's Avatar
Definetly a truck, NOT a car, my mistake!
My bad about the car remark, should've caught it. I would like to the TRUCK up a bit (lol), but i was looking for suspension lifts, I think. I thought the only good a body lift did was get the body up high enough to fit bigger tires underneath. I have enough trouble getting up anything steep with the size tires i have now, i don't want to get bigger tires if i can avoid it. My dad has a 97 and he just put on a 3 inch OME lift, and that works badass for him, as in a recent trip to Moab, he kept from scraping anything except his hitch. Anyway, thanks for the advice
Old 04-05-2004, 02:38 PM
A bodylift will put the body up away from the frame.
A suspension lift will put the body and frame up away from the suspension.
You don't want bigger tires but want things out of the way?
Does your dad have a button that says "RR Locker"?
Old 04-05-2004, 10:03 PM
AxleIke's Avatar
No, he doesn't, is that the button for the electric lockers that Toyota makes? I tried to talk him into air lockers, but he only wants them in the rear becasue he says that he has to go to manual hubs if he goes with a locker in the front. Do you know if that is true? He is attached to his automatic hubs, since he often drives in the snowy weather here in Colorado, and i can't say that i blame him.
Well, i only have the 4 banger in my 4runner, and while it does just fine offroad in low four, it is pretty gutless going on the highway. Plus, i find myself having to give it more gas than others on some obstacles because it just doesn't have what it takes. I am putting on new headers, exhaust and intake, but that isn't going to help much. I'm afraid that if i get bigger tires, i'll be losing too much power. I'm trying to raise up that darn fuel tank.
Thnks
Old 04-05-2004, 11:37 PM
anthony1's Avatar
If you want to raise the fuel tank, get the 2" bl. You can raise the tank 2" after that.
You can also regear to put the power back when you go larger tires.
If you go with Manual hub, you can always leave it locked during winter.
09-04-2015 09:27 AM
88sasturbotoy
08-11-2015 01:56 AM
coffey50
07-28-2015 10:55 AM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: Best Lift Set up
