Benefits to a deckplate mod. - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 03-22-2007, 07:28 PM   #1
What are the benefits? Could a semi-noob do it? It looks easy, take out the box, trace, cut the screw, and put back in.
BYAHnate is offline   Reply With Quote
Old 03-22-2007, 08:01 PM   #2
111db's Avatar
Yes it is easy. Its been covered in a million threads here, it would be to your benefit to use the search function to find the answer you're looking for. My opinion of the deckplate mod is probably in the minority.
111db is offline   Reply With Quote
Old 03-22-2007, 08:03 PM   #3
91_4x4runner's Avatar
The benefit is that cool sucking sound when you hammer it! :-)
91_4x4runner is offline   Reply With Quote
Old 03-22-2007, 08:03 PM   #4
I already have a 40 seires flowmaster, how much louder will it be?
Old 03-22-2007, 08:04 PM   #5
HuskyRunner's Avatar
Makes it sound like a V8! Possible improvements in milage, and horse power. And yes, it's really easy. Took me longer to find my Dremel than to do the mod.
HuskyRunner is offline   Reply With Quote
Old 03-22-2007, 08:07 PM   #6
Will it be louder, or just improve the tone? Remeber FLOWMASTER 40.
Old 03-22-2007, 08:12 PM   #7
It won't change the exhaust note at all. It is the intake sound that changes, sort of a whooshing sound. Combine it with your Flowmaster and it should sound pretty good
Old 03-22-2007, 08:23 PM   #8
To take the airbox out, do I only have to takew the 3 bolts out, Or do I also have to take the two small bolts on the large air sensor off as well?
Old 03-22-2007, 08:42 PM   #9
Sponsoring Member
midiwall's Avatar
DOESN'T ANYONE SEARCH ANYMORE????
DOESN'T ANYONE LOOK IN THE TECH WRITE-UP SECTION????
geez
The 3.4L is starved for air based on how the airbox is designed. Doing the deckplate will relieve that situation, giving a dyno proven net gain of about 6hp.
The added noise comes from the air being sucked into the box through the new hole. It's noticeable, it's a nice addition to the sound of your tailpipe.
midiwall is offline   Reply With Quote
Old 03-22-2007, 08:44 PM   #10
drunberg's Avatar
Midiwall beat me to the search whacking.
try this link:
/f130/deckplate-mod-75169/
Look in the knowledge base, it will answer many of your questions
drunberg is offline   Reply With Quote
Old 03-22-2007, 08:46 PM   #11
99LimitedKS's Avatar
The difference is noticeable. No doubt about that.
99LimitedKS is offline   Reply With Quote
Old 03-22-2007, 08:47 PM   #12
jwbehm's Avatar
Together with the ISR mod and it will be realllllly loud. I Just put the airaid tube on mine and now it sounds really good.
jwbehm is offline   Reply With Quote
Old 03-22-2007, 08:58 PM   #13
Save your duckets..............cuz I've been flushing tham down the toilet for the last few years.
Plugged it up and got my efficiency back...........3.00 a gallon coming soon to a town near you!
K>>S
sharrack is offline   Reply With Quote
Old 03-22-2007, 09:07 PM   #14
BajaRunner's Avatar
I like the sound of my deckplate, flowmaster 50 and turn down pipe all working in harmony with each other.
I literally had a guy ask me the other day if I was running a v-8 in it. He was a semi-buddy of mine, so thats why he asked. But I was like.. no way dude. He said it sounded way gnarly, then said he thought it was like a v-12 or something when I pulled up into th eparking lot. hahaa
BajaRunner is offline   Reply With Quote
Old 03-22-2007, 09:19 PM   #15
coldwiz's Avatar
That's what is nice about it though - you can just plug it up when you want to and you're back to stock. I saw about a 1.5mpg drop after the mod. I plugged up last week to see if the mpg comes back up or if I was dreaming.
coldwiz is offline   Reply With Quote
Old 03-22-2007, 09:48 PM   #16
So what bolts have to be taken out to take off the airbox?
Old 03-22-2007, 09:52 PM   #17
Sponsoring Member
midiwall's Avatar
{echo} ... {echo}
It's even got piktures in dere, with pretty red circles around the answer to your question.
Old 03-22-2007, 09:54 PM   #18
Godzilla's Avatar
wow.../f130/deckplate-mod-75169/
Godzilla is offline   Reply With Quote
Old 03-22-2007, 09:57 PM   #19
bktaco's Avatar
just dig in there, you'll figure it out. sorry if that sounds harsh, but at some point you have to pick up the wrench and start turning it. if you get a few bolts undone and the airbox does not pop off, then find another one to turn out. and enjoy it! btw, there will be a couple screws too.
bktaco is offline   Reply With Quote
Old 03-22-2007, 10:11 PM   #20
Elton's Avatar
ban the newb for a week for not searching/looking
Elton is offline   Reply With Quote
Voids 1987 4runner 22re turbo - in over my head voiddweller 86-95 Trucks & 4Runners (Build-Up Section) 53 02-01-2016 06:46 AM
First Time Head Gasket and Timing Chain Questions _Nicco_ 86-95 Trucks & 4Runners 35 09-21-2015 04:06 PM
93 4runner ISR mod low(er) idle 128keaton 86-95 Trucks & 4Runners 9 09-14-2015 01:16 AM
2 Questions 85 4Runner - 1st about A/C, 2nd about Header DiggnDeep 84-85 Trucks & 4Runners 4 09-03-2015 03:45 PM
Zuk mod help Massmayhem247 86-95 Trucks & 4Runners 2 07-18-2015 06:46 AM
Tags
4funner, 4runner, 50, advantages, air, benefits, deck, deckplate, flowmaster, intake, isr, mit, mod, plate, raid
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
