Belt squeal? which one to replace
Since it has been in the negative tempeture here, it seems like all these wierd noises pop up. I am getting a belt squeal but am having a hard time figuring out which belt it might be. Here is the issue, it will only squeal when I am driving and let off the gas, it will stop if I am accelerating, also it won't squeal if I am stopped or driving under 30mph. It will also stop if I drive the truck for about 30 minutes. Any idea's?
I'd worry less about which one it is and just replace all 3. The additional expense and hassle are very minimal to change a single belt vs. all of them. Chances are they're all the same age with the same amount of wear, and if one's going, then it's time to change them all.
go to kragens and give them the year,make,engine and i think a factory option are needed.. the cashier will then get them for you.
if he tries to sell you the expensive ones with nano technology or warp drives or something, just get the cheap ones.. belt technology has not changed much
my first time doing all 3 belts took me a little under an hour with 2 sets of hands
Replaced the belts this weekend. Spent $30.00 for all three belts. Maybe it was just me but I had a hell of time trying to get to all the tension pulleys to loosen the belts. Oh-well hopefull I won't have to do this again.
Did it stop all the squeals? Belts are a wear-and-tear, routine maintenance item, not to mention the accessories they run, which can fail. Hopefully you won't, but if you keep the truck, you could be right back in there at some point, so don't write it off as "done forever."
TURBOrunnerNM
07-22-2015 11:01 AM
rushw
07-18-2015 01:46 PM
