Belt slipping?
Belt slipping?
In December 2008 (3 months ago aprox) I got all my belts replaced (A/C, Alternator, and Power Steering) and when I start my I hear a high pitch skretch for a second that sounds like a typical car with the belt slipping, it goes right away and never hear it again till I start my car up again. Should I be concernced?
Shouldnt be much of a problem if your still charging and turning the water pump etc.
Just go and retighten them they may have stretched a little bit since they are new
I think belt dressing is a horrible idea! It makes a big mess everywhere. A belt is an easy low cast item that should be replaced or adjusted. I have also seen where people use belt dressing then it turns into where they have to use it all the time otherwise the belt squeeks worse
primordialbeast117
12-19-2015 12:23 PM
