Belt Replacement
Belt Replacement
I have a 1991 w/ the v6, 3vz-e engine.... the garage was supposed to change the belts when it was in for inspection (and didnt).... so rather than send it back I am just going to save a buck and do it myself.... while inspecting the existing condition I see only 2 belts.... Is this correct?... there appears to be a pully with no belt on it down deep on the left hand side.... I havent noticed any "problems" with performance?..... could this be a belt than runs the A/C.... have I been sweating my b@lls off all summer because of a simple belt replacement ?.... If so does anyone have a belt "routing" digram (or picture) they could attach so I know what it should look like?.... many thanks
supposed to be three belts... sounds like the other is the AC belt... prolly disconnected cause the system leaks and doesn't work... i cant find a pic or diagram anywhere... sorry
A/C worked last summer after I had it recharged... I assumed it leaked and thats why it wasnt working this summer... I never thought I would have lost a belt... Must have happend while the wife was drivin' it
Thanks all... I looked in the Haynes Manual... they have each belt broken out into there respective sections.... i.e. the belt that runs the alternator is in the electrical section... they don't show all three as a "system" under a "routine maintenance" section... kinda dumb I think.... I don't expect the job will be too tough... It just felt good to vent a little... I'm feeling much better now
TURBOrunnerNM
07-22-2015 11:01 AM
rushw
07-18-2015 01:46 PM
