Battery Drain with Full Time Outlets? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-16-2003, 09:19 PM   #1 (permalink)
LSUMatt1514's Avatar
Send a message via AIM to LSUMatt1514
I've been meaning to do this mod for some time now and I think I might tackle it tomorrow. A couple of quick questions for ya'll.....
1. Will this mod supply full time power to the fuse box in the cab?
2. Would a cell phone draw enough to drain the battery with the truck off?
I'd like to be able to charge my cell phone with the truck off, but I also have my radar detector hard wired into the fuse box. If the fuse box will get power all the time with this mod, I'm wondering if it has the potential to drain the battery. Opinions?
Later.
Matt
__________________
01' SR5 Sport Edition
Performance: Deck Plate w/ Amsoil Filter, ISR Mod, Dynomax Super Turbo w/ Pacesetter Tip
Exterior: Manik Brush Guard, Piaa 1000X, Piaa 540, OEM Skid Plate, Custom Sidemarkers, Clear Corners/Bumpers, H/L Alenzas, Thule Lappland Cargo Basket, Reverse Lamps, Silverstars
Interior: Stereo System, Dakota Digital Gauges, Coleman Inverter, Speedhut Gauges
http://community.webshots.com/user/phi1514
LSUMatt1514 is offline
Old 05-16-2003, 11:18 PM   #2 (permalink)
Hi Matt,
I have a hardwired Valentine (thanks for your help waaay back when) which is tapped into a 12V accessory wire from the ignition bundle. The write up is at http://www.4runners.org/articles/valentine/ It will only power when the ignition is switched on.
Also, I added a single, full-time 12V outlet like you are planning to do. That write up is at http://www.4runners.org/articles/12v I used ASUDan's write up as a guide, but instead of using the type of outlet he used (lotsa glue), I bought one that can screw onto itself (a no glue install). Check out the write up to see what I'm talking about and try to find the same kind.
I also followed Corey's advice and added a 12V auxiliary fuse box inside the engine compartment. Read 'Step 6' in my Cobra CB write up at http://www.4runners.org/articles/cobra . I bought the parts from Waytek but I've recently seen it sold at Pep Boys. If you haven't done it, its definitely worth doing b/c it really allows you to easily add power for future accessories.
As for draining out the battery, I really have no clue. I know you can buy a box that will switch off power by voltage and/or by some set time. See http://www.4x4wire.com/toyota/4Runner/tech/chargeguard/
From personal experience, I've powered my mobile phone for 3 hours and when I came back, there was no problem starting the 4runner. I haven't left it on overnight so I can't say for 100% sure that it would drain the battery.
In anycase, the V1 and the Garmin are things that I NEVER leave out in the open so when I stop and park, those things get turned off and locked away.
Email or PM me if you have any questions.
Bob
Bob_98SR5 is offline
Old 05-17-2003, 01:44 AM   #3 (permalink)
jx94148's Avatar
Send a message via Yahoo to jx94148
Probably not. But how often do you need the radar detector to be on when the engine is not running? Wire it so you can charge your cell anytime and your radar detector comes on with ignition. The two devices combined might discharge the battery enough so that it won't start in adverse conditions. Why gamble when its easily avoided?
jx94148 is offline
Old 05-17-2003, 10:31 AM   #4 (permalink)
jalaber's Avatar
This is truly a minute mod. I recently did it and was wondering the same thing...how long will a small device like a cell phone drain the battery?
__________________
-J.A.
2007 4Runner Sport
1999 4Runner Highlander
My Runners
4Runner Topsites
4Runner Diecasts
jalaber is offline
Old 05-18-2003, 12:29 PM   #5 (permalink)
Send a message via Yahoo to SteveS
Jalaber
Whats that red wire in the top part of your picture for?
I know the other is the outlet jumper.
ZR2Steve
SteveS is offline
Old 05-18-2003, 12:36 PM   #6 (permalink)
Shane's Avatar
Send a message via AIM to Shane
Quote:
Do the math, how many milliamps per hour does the charger draw and how much reserve amp/hours does your battery supposedly have.
1000 milliamps = 1 amp
__________________
"It's one great big dysfunctional family that now has to split up and spread dysfunctionality around the greater world," Bill Stainton on the breakup of the cast of "Almost Live!"
Shane is offline
Old 05-19-2003, 06:25 AM   #7 (permalink)
jalaber's Avatar
Quote:
Originally posted by SteveS
Jalaber
ZR2Steve
It is a jumper wire which brings power from the parking lamp fuse to the factory fog lamp circuit so I can use the fogs whenever the parking lamps are on rather than just when the low beams are on. Full write-up on my site.
__________________
-J.A.
2007 4Runner Sport
My Runners
4Runner Topsites
4Runner Diecasts
jalaber is offline
Old 05-19-2003, 01:00 PM   #8 (permalink)
Thanks.
Fog lamps, I don't have those.
I'm always looking for useful mods, and have spent some time in the stock fuse box.
SteveS is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
05 full power for cig lighter and power outlets 05SportTaco 03+ 4Runner/GX470, & 05+ Tacomas 4 01-19-2006 07:37 PM
Full Time Power Outlets - 01 Tacoma Bob_98SR5 Electrical 0 12-31-2005 08:21 PM
part time job + full time student = cant afford gas gtm130 95.5-2004 Tacomas & 96-2002 4Runners 8 07-28-2004 08:34 PM
Full time power outlets - 2003 4Runner? Billf6531 95.5-2004 Tacomas & 96-2002 4Runners 10 06-09-2003 06:17 AM
Need help...battery drain rpeAMP 95.5-2004 Tacomas & 96-2002 4Runners 3 11-05-2002 01:14 PM
2009 InternetBrands, Inc.
