Bank 1 sensor 1 = before the cat? 2000 4runner - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 08-25-2008, 01:18 PM   #1
Got the code read, o2 sensor, bank 1 sensor 1, got the new sensor from stealer but when I asked which one it was they were not too helpful just told me what I told them,, bank 1 sensor 1, when I asked if it was on the exhaust before or after the cat they just told me it is on the exhaust (I don't know maybe they are pissed I'm not having their techs put it in for me), or the parts guys just didn't know.
I'm sure one of you out there knows this one...
Please help.
Thanks
Tom
tommytuttle is offline   Reply With Quote
Old 08-25-2008, 08:31 PM   #2
bank1 sub 1 is the sensor before cat,sub2 is after cat.....engine-->sub1--->cat--->sub2.
Probably a heater circuit malfunction,replacing the sensor should fix your problem....Next time get the actual code#,it can help in diagnosing the problem in the future.
97ltd4x4 is offline   Reply With Quote
Old 08-25-2008, 08:44 PM   #3
netwt12's Avatar
bank 1 is on the number 1 cylinder side. sensor 1 is before the converter.
netwt12 is offline   Reply With Quote
Old 08-26-2008, 12:08 PM   #4
i just changed this. look under the pass side by the front wheel on the exhaust pipe. make sure you get the right sensor. theres one for cali spec and non cali spec. dealership can tell you if you supply them with your VIN#
make sure you get the gasket and 2 new nuts.
HiluxSurfLTD is offline   Reply With Quote
Old 08-28-2008, 06:06 AM   #5
Thanks everyone.
Quick correction I meant to say sensor 2
Code is P0141 Bank 1 Sensor 2... so that is the one after the cat...
Ironically I just replaced the nuts on both studs 3 months ago, sensor 1 (before the cat) popped out on a trip, nuts rusted right off.
Should be a simple fix.. connector looks easily accessable.
The dealer did use my vin number when ordering the part so hopefully all is correct. Is there anyway I can double check my part number and vin number to confirm all is correct... and that I have the bank 1 sensor 2?
Thanks all
Old 11-12-2008, 07:31 AM   #6
Where is the sensor Bank 1 Sensor 1 located...I can't find it.
Thanks
ndrj is offline   Reply With Quote
88 Pickup Transmission Swap mskalmus 86-95 Trucks & 4Runners 6 03-21-2016 12:41 PM
Radiator leak. Now where to? (2000 v6) Avenged 95.5-2004 Tacomas & 96-2002 4Runners 4 07-09-2015 08:55 AM
2000 camry wont start Huntingtruckcletus Other Makes Cars/Trucks 0 07-08-2015 06:26 PM
4runner stalling in gear... Do this again please Jnkml 95.5-2004 Tacomas & 96-2002 4Runners 3 07-06-2015 02:20 PM
speedometer 'freaking out' wilbertd 86-95 Trucks & 4Runners 2 07-06-2015 08:39 AM
Tags
1997, 1sensor1, 2002, 2003, bank, camery, camry, cat, chevy, engine, o2, s10, sensor, sensor1, sensors, t100, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
