banging noise in front brakes after perf. friction pad install?
Old 08-24-2005, 08:31 AM
bflooks's Avatar
hey guys. i know it is somewhat common for the 4runner to get the "bang" from the pads while changing the directions for the first time you apply the brakes. something about the pads not being completely locked, and having a little room between themselves and the callipers. i have a 98 runner with the factory 16" wheels. i put pbr brake pads in the last time i did front brakes, and did not have an issue. this past time (about 5k ago), i put in performance friction pads. since the install of the new pads, i have the bang/clunk. it is rather annoying, and i was wonderring if this is common from the pf pads or not. i am almost ready to change them out. but if there is something simple i can do to stop it, then i will def. do it, as i have no other compaints with the pads.
Old 08-24-2005, 09:19 AM
MTL_4runner's Avatar
Something is not right there.
Did you recheck the hardware again to ensure everything was tight?
Old 08-24-2005, 09:36 AM
bflooks's Avatar
i did verify that everything was installed properly. and it is. the only thing i can think of is that the slots in the pads that the retaining pins slide through are a little more of an oval shape as opposed to a circle. i am contributing this to the fact that these exact pads work in other makes/models. either that, or i am just pulling that out of my butt, and i have no idea what i am talking about, but these brakes are NOT hard to work on at all. i can't see where i could have missed something.
Old 08-24-2005, 11:19 AM
Guest
94x4's Avatar
Are the retaining springs/clips properly in place and not reversed?
Old 08-24-2005, 11:48 AM
bflooks's Avatar
nope, everything is in place. the springs are in place as well. the clip part in the center of the springs are on the inside part of the calliper. the pins are in so the springs line up with the holes in them. all the shims are in place as well as the huge clip that goes over the pads.
Old 08-24-2005, 03:33 PM
Crux's Avatar
Maybe post some pics?
Old 08-24-2005, 06:07 PM
bflooks's Avatar
post pics of what? the front brake assemblies? i can do that, but it won't be until saturday sometime. thanks for the help guys. i will post some pics up on that day.
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
bryan34w
07-06-2015 05:53 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: banging noise in front brakes after perf. friction pad install?
