Bandit Runner's Grille Mod - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-09-2009, 08:07 AM   #1 (permalink)
Bandit Runner's Avatar
I finally got around to finishing my grille modification. It is a little different than the Satoshi mod, but as usual, I always try to be a little different than the rest.
Here's what it looked like before I started. (Sorry, its kind of hard to see.)
I used my 2002 grille and cut out all of the vertical and horizontal ribs leaving two open sections. I covered the nice glossy surfaces with blue painters tape to protect them while cutting, filing and sanding the ribs out. It looked like this:
The horizontal rib in the upper opening intersected the center oval shape, so when I cut that rib out, it left a hole in the top of the oval. I had to epoxy some plastic pieces and bondo it to fill it back in. You can kind of see it here:
For the screen mesh, I ordered some 3/16" hole pattern aluminum mesh from McMaster's. It very closely matches the mesh inside the hood scoop area. Here are the two pieces cut out to fit behind the openings:
Then I painted the grille openings and mesh semi-gloss black.
To attach the mesh, I had to epoxy some plastic chunks to the back of the grille, to screw the mesh into. (Sorry, I forgot to take pics of the back of the grille, to show the attachment, but no screws can be seen from the front) Here it is with the mesh attached:
Here it is completed in the truck:
I really like the way it turned out. It looks much cleaner without all of those odd-colored ribs in there. When I build my custom bumper next spring, It will have openings in the front that will be filled with the same mesh, so everything matches.
__________________
Bandit Runner
2002 4Runner Sport Edition, Black, 4x4
Currrent Mods:
265/75R16 Firestone Destination M/T's, Extended Rear Diff Breather, Running boards removed, 4Crawler 1.5" body lift, Deckplate Mod, ISR Mod, Andy Trac Off Mod, Custom Front Skid Plate, Customized 4xInnovations slider steps, Eagle Alloy Series 1378 Aluminum Wheels, Daystar 2.5" spacers in front, OME 890's in rear
Coming Soon:
Custom front bumper
Future:
Sonoran Steel 1.2 Lift
35" Mickey Thompson MTZ tires
Bandit Runner is offline
Old 11-09-2009, 08:30 AM   #2 (permalink)
02_Limited's Avatar
Send a message via AIM to 02_Limited
Nice, subtle and clean mod. If you're not a fan of that odd colored grey plastic that's in your front valence, painting it black makes it look a little better. At least it looked better after on my Silver 4R, on your black one I could only imagine that it would look even better
__________________
2002 Limited 4wd
On the outside:
3.5" full OME lift, 33" Terra Grapplers, TRD cat back, full LED lighting/LED tails, amber Hella 500's and more odds and ends
On the inside:
TomTom|Infinity|Kicker 08ZX750.1|08CVR12|Jensen VM9412/iLink|Dynamat|Complete LED conversion
In progress:
ZEX NO2 injection
Lockright
Quote:
Originally Posted by habanero View Post
Throttle Positioning Spider?
02_Limited is offline
Old 11-10-2009, 12:32 PM   #3 (permalink)
Thanks, yours looks real good too!
__________________
Bandit Runner
Currrent Mods:
Coming Soon:
Custom front bumper
Future:
Old 11-10-2009, 12:56 PM   #4 (permalink)
X-AWDriver's Avatar
Nice mod bandit;I like to get around to doing mine in a similar fashion.
__________________
'99 4Runner Highlander 4wd
E-locker,rear diff and deckplate mod * 265/75/16 Nitto TerraGrapplers * Yakima Load Warrior rack * clear corners/signals * Tacoma skidplate * Silverstar lamps/fogs
Alpine CDA-9831,Bazooka EL Series 250w amp,MTX 10" sub
X-AWDriver is online now
Old 12-18-2009, 10:09 AM   #5 (permalink)
bak3rme's Avatar
that looks hellllllllllllllllllllaaaaaaaaaaaaaaaaaaaaaaaaaaaa a good man good job
bak3rme is offline
Old 12-19-2009, 06:58 AM   #6 (permalink)
emptypockets's Avatar
What a clean looking mod. I've been wanting to do this myself and seeing yours definitely helps the decision! The only problem with my rig is that the grille's chrome and my rig is white. So doing mine in black is out of the question. Maybe an aluminum color would work well...would match the mesh at least.
__________________
Model: '02 4Runner SR5 - White On Natural Oak, Tan Interior
Engine/Performance: 3.4L V6, Auto, AndyMod, Jardine Catback Exhaust, S&B Intake
Rear Suspension: 3.75" lift with LC coils and Rancho RS5000 shocks
Front Suspension: 3" lift with OME 882 springs and OME N91sc shocks, Diff Drop
Tires: 285/75 R16 Fierce Attitude M/T's, Pacer 164P Alloy Wheels
Misc: Full Time Power Outlet Mod, Extra Power Outlet Mod, GE Nighthawks
emptypockets is offline
Tags
grille, mod, satoshi, tacoma
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2009 InternetBrands, Inc.
