Ball Joints
Old 08-05-2002, 01:39 PM
williemon's Avatar
Ball Joints
I need to replace Ball joints on the 90 4 Runner. Any special tools needed? I have a "pickle fork" already. Anybody with instructions? I was told it needs uppers, but I might need to do uppers and lowers.
Old 08-06-2002, 01:30 PM
williemon's Avatar
Anybody???
Old 08-07-2002, 12:31 PM
williemon's Avatar
Anybody at all?? Come on now!! Sombody has to have done this before. How about it....Yoda.....Corey......anybody???
Old 08-08-2002, 10:01 AM
paddlenbike's Avatar
Ball joints hate me and I hate them.
A ball joint separater is an easy way to remove a ball joint. Consider yourself forewarned though that it will likely tear the rubber boot.
Use could also use a ball joint puller that looks something like a harmonic balancer puller.
I want one of these:
$25.99 from Harbor Freight.
All I can say is good luck!
Ken
Old 08-08-2002, 10:28 AM
Co-Founder/Administrator
Staff
Corey's Avatar
Sorry williemon, never tackled that before.
I thought for sure Paul or Master Yoda may have.
Corey
Old 08-08-2002, 10:31 AM
williemon's Avatar
Anybody know if the replacements from the auto store are pre greased, or do I need to zerk them and install some grease? Also, if I do grease them, should I use a synthetic grease that I already have, or use a convintional grease?
Old 05-19-2003, 12:01 PM
I need to replace my ball joint boots. Any advise out there? Any links?
Thanks
Old 05-19-2003, 07:57 PM
Firefyter-Emt's Avatar
Very easy job... The ball joints bolt in to the control arm, and you will need to grease them.. The fitting will come with them, just grease them after you have them all put in.. All you need is that fork tool to pop the joint and a good 4lb sledge (makes the job eaiser than a light ball peen hammer)
Old 05-19-2003, 08:33 PM
Victor's Avatar
Lee is right. Buy a big ass hammer - don't waste your time banging with a claw hammer.
Old 05-19-2003, 08:52 PM
OneTrickToy's Avatar
I used a 4lb maul to seperate my tie rod ends. I'm sure it will be about the same doing the ball mounts.
Old 05-19-2003, 10:13 PM
Thanks for the advice. I'll be doing the ball joints after I manage to install the headers and exhaust. The header installation was working out great until I broke a bolt. ugghhhhhh
Thanks again
Old 05-22-2003, 10:32 AM
williemon's Avatar
I learned the hard way that I needed a BFH!!!! Bought one at sears the next day. Then the removal was easy and so was the install. Guess I need to grease them.....
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
4x4YOTA
08-23-2016 09:08 AM
crash813
09-27-2015 07:15 AM
Odin
09-26-2015 06:56 PM
Quick Reply: Ball Joints
