Bad U-Joint, Recommendations? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
New! Use your Facebook to securely log into this site, click logo to login
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-05-2010, 12:14 PM   #1 (permalink)
I have a bad u-joint and have heard that replacing the drive shaft is recommended.
I have also heard/read where the aftermarket U-Joints are not the right tolerances for the stock drive shaft. So the drive shaft has to be machined, with additional costs and time. And it's no guarantee that it will work. (I don't like the sound of this route.)
Toyota replacement parts are fairly cheap
U-Joint $69.95
Drive shaft $98.95
What has anyone else done?
2001 2wd 3.4l Limited
trythefly is offline
Old 01-05-2010, 12:44 PM   #2 (permalink)
Gerdo's Avatar
If the u-joint is going out and hasn't completely fallen apart, I wouldn't see any reason to replace the drive-shaft.
I haven't heard that aftermarket u-joints don't fit. I also don't know why you should replace the driveshaft.
__________________
2000 4Runner Sport, 3.4L, 5 Speed, Custom Front Winch Bumper, Opened intake, K&N Airfilter, Yokahama AT/S LT265/75R16, Bilstein Shocks, FreeFlow Exhaust, Poly Rack Mounts & Swaybar Mounts, Tundra TRDs up front and OME 891s out back. ToyTec Panhard Bar Drop. SS Front Diff Drop. Home-built 2x2 Sliders. ARB rear locker, OBA, CO2 See My 4Runner!
3rd gen 4runner fuel tank skidplate http://lilskipsoffroad.wordpress.com/ Thread link to YT sales
Gerdo is offline
Old 01-05-2010, 12:52 PM   #3 (permalink)
northfacer581's Avatar
i just had my rear u-joint replaced. the one at the rear diff. toyota did it for me and it solved all my problems. the joint was pretty bad, but i saw no reason to replace the driveshaft, and neither did they (which is surprising)
id say just get the u-joint replaced and go from there.
__________________
-Andy
99 4runner. 5spd. Supercharged.
northfacer581 is offline
Old 01-05-2010, 01:36 PM   #4 (permalink)
I don't want to spend the extra 100 bucks for the new drive shaft if I don't have to.
How hard are the u-joints to replace? Can they be tricky?
__________________
-trythefly
2001 4Runner 3.4 L
5VZ-FE V6
Old 01-05-2010, 01:43 PM   #5 (permalink)
theyre not very difficult. its just you have to take the driveshaft off, and remounting it and making sure its properly balanced is the tricky part. id say its a 3 or so banana job outa 5.
__________________
-Andy
Old 01-05-2010, 01:44 PM   #6 (permalink)
lol thanks Andy
__________________
-trythefly
2001 4Runner 3.4 L
5VZ-FE V6
Tags
4runner, bad, drive, joint, joints, shaft
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Contact Us - YotaTech - Archive -
Top
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2010 InternetBrands, Inc.
