Is this bad?!?!
Old 10-17-2004, 07:12 PM
Yamaha+Toyota=Fun's Avatar
Is this bad?!?!
I just noticed this on my truck the other day. I just bought my truck 2-3 months ago and never noticed this. Could this cause any problems/decreased perfomance.
Old 10-17-2004, 07:18 PM
Plays_with_Toys's Avatar
How does it run now? It looks like that vacuum line goes to that black nozzle right next to the silver box.
Old 10-17-2004, 07:21 PM
It seems like it runs ok. I dont know if the previous owner did this for a reason. Or he was just a had an extra zip tie.
Old 10-17-2004, 07:31 PM
Bumpin' Yota's Avatar
that hose should go on the intake plenum where there are 2 hoses and that one nipple. What it does I have no idea....where does that hose run to?
Old 10-17-2004, 07:47 PM
ayoung101's Avatar
there's one really easy way to find out! it's just a vacuum line. unhook it and plug it into that spot for a vacuum line right next to the hose. take the truck out for a spin and see if you notice anything different in your performance. if it gets better, then good. worse, then take it off and zip tie it shut again.
Old 10-17-2004, 07:48 PM
I think this is where its suppost to go. Anyone with a 22re have a manuel they could check real quick?
Old 10-17-2004, 07:54 PM
evilcow's Avatar
Under the hood there should be a vacum hose diagram.
Old 10-17-2004, 07:57 PM
ayoung101's Avatar
i didn't even see that spot. i was thinking maybe here.
Old 10-17-2004, 08:01 PM
ayoung101's Avatar
don't know if his is the same way, but my sticker is worthless. can barely see what's written on there anymore. an repair manual would be better. i'd help you out but mine is back at home (and i'm up at college).
it shouldn't be too hard to find where it goes. the 2 possible spots (that we can see from the picture) appear to be different sizes. meaning, the hose will only fit snug on one of them. trial and error, 50/50
Old 10-17-2004, 08:04 PM
AgRunner06's Avatar
It looks like what you have circled is the egr valve but I bet it goes on that black piece just below it.
EDIT: I didn't look at your second circled pic but that's the one I'm talking about. However, after looking at my manual, it does show a vacuum line going into the top of the egr valve.
Old 10-17-2004, 08:05 PM
I dont even have the diagram! Ill try hooking it up and see what happens. Im gonna find out what that is or else its gonna bug me for along time!!
Old 10-17-2004, 08:06 PM
Erich_870's Avatar
My manual says that's the EGR Valve for an 88 22R-E. I know yours is an 89 but my vacume diagram shows it should have one vacume line comeing off at the nipple Y+T=F highlighted. I can't make out any more specifics from your pic, but I'd try it and see what happens
Erich
Old 10-17-2004, 08:08 PM
ayoung101's Avatar
i can't tell. i hate vacuum lines. WITH A PASSION. don't understand em. don't know how or why they work. and they all look the same! stupid little buggers. . . .
Old 10-17-2004, 08:12 PM
What is the egr for, emissions?
Old 10-17-2004, 08:13 PM
Nathan Buchanan's Avatar
Here's a diagram: http://personal.utulsa.edu/~nathan-b...14layoutan.pdf
'93 Service Manual http://personal.utulsa.edu/~nathan-b...fsm/index.html
Old 10-17-2004, 08:14 PM
AgRunner06's Avatar
I just edited my reply. Can you take another pic from farther away so we can see what else is located around it?
Old 10-17-2004, 08:24 PM
Here is a pic from a bit further out.
Old 10-17-2004, 08:27 PM
Erich_870's Avatar
The bottom of the first diagram Nathan posted is very intersting. It looks to me like the EGR valve allows for the monitoring of the exhaust gas pressure. Does it look that way to anyone else? It passes through the exhause valve and into the headers and then branches off to a cooler then the the EGR valve which when open goes to the EGR vacume modulator and then what? At times those gases can go back into the throttle body? Or are they just routed to the EGR Vacume Mod for and end there? Nathan
Erich
Old 10-17-2004, 08:31 PM
I cant view the files, I dont have adobe acrobat.
Old 10-17-2004, 09:06 PM
NorCalVP's Avatar
From looking at the link above, it looks like it goes where you first thought it did. On the EGR valve.
Quick Reply: Is this bad?!?!
