backspacing
Old 01-13-2009, 04:32 PM
PITBULL2888's Avatar
backspacing
help please i'v searched but caint find the awnser.
if i get the bfg km2 33x10.50x15 and put them on Pro Comp rock crawler Wheels Series 97 15x8 which back spacing do i need?
i only see them in a 3.75 and a 4.00 i think.
and will the center cap on these wheels fit over my manual hubs?
thanks
Old 01-13-2009, 06:15 PM
AsILayDying692's Avatar
Wut year truck you have i know TTora has a list of wheels that fit and dont fit and i know those wheels would not fit on my 97 tacoma cause of the brakes
Old 01-13-2009, 06:21 PM
it's a 1998
Old 01-14-2009, 09:23 AM
Conatus's Avatar
You must use 16" wheels to clear the brakes.
Also, the backspacing on stock wheels is around 4-5/8". If you plan to run tires that are 11" wide or wider, you will need less backspacing. Best is to test mount your wheel tire combo.
FWIW most that run 33"-35"X12.5" tires run a 3.5" backspaced wheel like the Mickey Thompson Classic II's.
I have around 5" of lift body and suspension with 4.5" backspaced wheels and a -12mm offset. I clear the UCA's just fine but get frame rub at full lock. I will be installing 1" wheel spacers to alleviate that problem.
Do some searching and you will find many answers.
Old 01-15-2009, 06:16 AM
how is that the stock wheels are 15" and they fit over the brakes why cant i get 15x8" wheels with 3.75 backspacing?
Old 01-15-2009, 06:50 AM
darksoldier313's Avatar
the problem with backspacing is u change the scrub radius 9 times out of 10 depending on how u change it u can get some weird tire wearing
Old 01-15-2009, 07:14 AM
but how is a 15x8" wheel going to not fit over the brakes when the stock wheels are 15"s
Old 01-15-2009, 08:24 AM
Conatus's Avatar
My bad, I thought you had the larger brakes that require 16" wheels. so obviously 15's will work. Good luck.
Old 01-15-2009, 10:39 AM
thanks. so what do you think about the backspacing i need im going to get a 3" toytec lift and i might get a 3" body lift down the road
Old 01-19-2009, 05:09 PM
ericdg16's Avatar
Not sure about the 4 runners, but in some other vehicles I have owned the stock 15" wheels are steel and therefore the metal is thinner (cause its a stronger metal).
Alot of your aftermarket wheels are aluminum which is a softer metal therefore the ID of the wheels is a little smaller due to the fact they have to be made thicker to maintain the same level of strength. Which could create the need to go to a larger diameter even though your stock ones worked fine.
Its definitely something to pay attention to when buying new wheels.
Old 01-20-2009, 10:49 AM
my stock wheels are not steel. but i talked to 4 wheel parts thats where i was going to get them from and they said that they would not fit over the brake caliber.
wich wheels will fit my tacoma in 15x8"?
theduck21
09-10-2015 07:01 PM
Luvmeye22re
08-04-2015 03:53 PM
Cebby
11-19-2008 08:11 PM
ElwayLite
08-24-2004 04:23 AM
Quick Reply: backspacing
