Axle Codes
Axle Codes
I am looking at a 4runner to get its Rear E Locking thrid. The Axle Code is A04A. From searches, I am finding that it could be a 4:56 (brian894x4's site) and from off-road.com it says this is a 4:30. Does anyone know which code A04A or B04A is a 4:56? Yota tech has some info from a search, but the codes are a little conflicting. If you have factory 4:56 gears, would you post your axle code.
My wife's 1999 4:30 4runner E locking axle code is A04A.
Well I am really not sure. I know that you can buy a new 4:56 from Toyota with a E locker. Otherwise I don't know.
Originally Posted by <96 Runner>
I wasn't aware of a 4.56 3rd gen gear option. You sure about that?
The 3rd gen V6 4Runners with 15" wheels, (both 4wd and 2wd), came with 3.909s. The V6 4Runners with 16" wheels were 4.10 and with the e-locker option it was a 4.30. 4 cyl models with 16" wheels had a 4.56 ratio.
These are probably the best sites for checking on that kind of stuff, I know it helped me figure out what my 97 SR5 4wd V6 with 15" wheels had.
Vibrate Software
Top 4Runners
Vibrate Software
Top 4Runners
sgirt,
best thing to do is to call toyota usa with your vin #. sometimes it takes a few minutes to get through and to get your answer, but you get the DEFINITIVE answer.
bob
bob
I have pulled the part. The F/R came out of a rolled '98. Code is A04A and the gear is 4:30. Counted 43 and 10 on the rear. From a post above, it really doesn't sound like the 3rd gen 4runners came with 4:56.
I was looking or 4:56's, but the 4:30 will work. (Bob_98SR5, I will be pulling my 4:88 members today and installing the 4:30's. Will PM you.
The 4.56 gearing was available on the 3rd gens, 4 cylinder models w/ 16" rims came with this ratio. Both standard and autos had the same ratio. As for the locker I was under the impression that all the lockers were bundled with the 4.30 gearing and the 8.5" rear end as opposed to the 8" like most other runners. I know that some have modified rear ends to accomodate factory lockers, but it requires some grinding to make room for one of the pieces.
