awful vibrations
awful vibrations
im getting a ton of vibrations when i let off the throttle, and sometimes when accelerating some.
i just installed my rb 2" bl, with new poly bushings, and new front rotors and pads.
the vibes were present before these two things but not as bad.
they started after my suspension lift, OME and tundra up front, alcan pack and bilsteins in the rear.
it is really violent sometimes, and i also hear a slow rotating thudding sound when im slowing down, which i believe to be my CV's. i did do a 1" diff drop with the susp lift though.
anyone have any ideas and or suggestions on what to check
thanks.
thanks.
You can remove front drive line from the transfer case to the front axle and if it still vibrates it may be the rear drive line or differential or axles.
https://www.yotatech.com/forums/f2/found-source-vibration-driveshaft-whoa-94000/
check there for solution and answers...
hiluxinargentina
09-30-2015 05:51 PM
Odin
09-26-2015 06:56 PM
Toys4parts
09-26-2015 01:56 PM
