Awful grinding noise coming from Driver side wheel any suggestions??? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-08-2007, 11:54 PM   #1 (permalink)
ivanr's Avatar
I started getting an awful grinding noise from my driver side wheel and at first I thought I had completly used up my brake pads but after taking the tire off my pads are still half way. Now I'm confused as to where the grinding is coming from. Any help would be greatly appreciated. I have a '96 4WD Automatic 4runner. Thanks
__________________
Pro Comp 4" lift with DR Coilovers and TC Upper Arms, 305-70-R16 X-Terrains on 16 by 10" Weld Outbacks, TRD Supercharger, TRD boost gauge, 9.5 PSI Pulley, 305cc injectors, SS FTC-E, Innovate LM-1 Kit, Supra MAF, dual 12" FAL electric fans, Autometer A/F gauge, Walbro fuel pump, TRD transmission cooler, TRD adjustable fuel regulator, Poweraid throttle body spacer, K&N filtercharger system, Jet Performance ECU Upgrade, TRD headers, TRD Thermostat, Flowmaster exhaust system
ivanr is offline
Old 01-08-2007, 11:56 PM   #2 (permalink)
Staff
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
Wheel bearings. Also, check your rotors for damage. If a rock scored them up, they would be eating the pads and causing a horrible sound since they would be misshappen.
__________________
Tacoma miniheader install kit Now available! Click here for ordering information
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by space-junk View Post
DeathCougar, you know everything!
Quote:
Originally Posted by fustercluck View Post
Now I know DC is a leader.
DeathCougar is offline
Old 01-09-2007, 10:24 AM   #3 (permalink)
ivanr's Avatar
Thanks. I know it's not the rotors because I took apart that whole side of the suspension and added new brakes and the rotors were clean. You're the second person that tells me its the wheel bearing. Is that something difficult to replace? Where could I find the parts for it? Thanks
__________________
ivanr is offline
Old 01-09-2007, 02:02 PM   #4 (permalink)
Elvota's Avatar
Jack the bad side off the ground and check for play side to side. A bad bearing will also probably spin very rough or have considerable drag.
A factory manual or at the least a Haynes manual will have the steps you need to follow. I'd check with Toyota for bearings.
__________________
1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000
- four wheels | three sticks | two hands | one trail -
visit the sticki chronicles
Elvota is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Grinding Wheel Noise mtltoyoter 95.5-2004 Tacomas & 96-2002 4Runners 1 06-11-2007 08:31 PM
99 3.4 weird grinding noise and water on drivers side? justin1889 95.5-2004 Tacomas & 96-2002 4Runners 8 11-22-2006 05:29 AM
strange noise coming from front driver side wheel PatHLC128 95.5-2004 Tacomas & 96-2002 4Runners 1 10-07-2006 08:58 PM
front driver side wheel well GoudyMan 95.5-2004 Tacomas & 96-2002 4Runners 1 12-19-2003 08:34 PM
Leak found near rear driver side wheel AJatx Maintenance & Repair Archives 29 01-27-2003 06:06 AM
2009 InternetBrands, Inc.
