auxilary lights wiring question
Old 06-27-2003, 03:01 PM
TStango's Avatar
I just got a set of Piaa 520's fog from Mike and I plan to install tonight. Does anyone have any suggestions on which wire I should tap into to relay the on/off switch and where is the best place to do so? I would prefer an ignition hot wire rather than limiting myself to usage of the Piaa's only when the low beam headlights are on. Thanks!
Old 06-27-2003, 03:03 PM
Co-Founder/Administrator
Staff
Corey's Avatar
See my write-up in the Tech section under Electrical.
You CAN have total control over your aux. lights.
No need to wire it the way the light makers want you to.
Old 06-27-2003, 03:04 PM
Tacoma Dude's Avatar
I've got some 520s that I installed using Corey's write-up.
VERY handy
Old 06-27-2003, 03:06 PM
TDiddy's Avatar
VERY handy
And I followed it when wiring up my Hella's!
Old 06-27-2003, 03:13 PM
Tom, everytime I see your avatar I'm thinking it looks so redundant. Just figured out why - this is what I keep seeing.
Old 06-27-2003, 03:19 PM
TDiddy's Avatar
Where'd that one come from, did you make one earlier? David did the CA one this morning I think.
Old 06-27-2003, 03:20 PM
no, did it just now...
Old 06-27-2003, 03:23 PM
TDiddy's Avatar
Ohhh, OK..
Old 06-27-2003, 03:31 PM
Old 06-27-2003, 03:52 PM
TStango's Avatar
Thanks Corey. That write up gave me some good ideas.
Old 06-27-2003, 07:20 PM
Staff
Corey's Avatar
You are welcome.
You might try the aux. fuse box mod later too if you anticipate tapping into more things.
It sure cleaned up my in cab fuse box, and makes it easier to tap for future mods.
Old 06-27-2003, 07:23 PM
keisur's Avatar
And it got me back on the right track when installing my LightForce 170's.
Old 06-27-2003, 07:31 PM
keisur's Avatar
Personally, I like my rendition. It seems to fit the "hello's" I get here in the wonderful city of Houston:
http://home.houston.rr.com/keisur/untitled[1].jpg
Old 06-27-2003, 08:07 PM
TDiddy's Avatar
Nice keisur, good one!
Old 06-27-2003, 08:25 PM
keisur's Avatar
I try.
smthwsn357
12-04-2023 02:08 AM
ashersullivan88yota
01-18-2022 05:37 PM
Johntom240
7
07-13-2015 12:18 AM
madxman21
07-09-2015 10:26 AM
colinmil
07-06-2015 04:03 PM
Quick Reply: auxilary lights wiring question
