Aux Back up/work lamps ..rack mounted ??
When I am working at the ski resort, I often have to park in some tight spots others may not try.
The back up lamps on my 98 are next to useless for this purpose.
I have looked into aux back up lamps mounted under the bumper on the trailer hitch but it seems the best spot, would be on the rear of my Thule basket.
Anyone done this ???
Any Pro's and cons ??
Thanks
David
Thanks
David
I've thought about locating some lights just under the bumper for this very purpose, but they'd be short-lived there if you did any measure of wheeling.
Thanks
David
Thanks
David
I have been seriosuly considering hiding two of these on my bumper, or maybe in the gate:
Luxeon V Star
12V Power Puck
Wide Beam Lens with Holder
They are darn bright, but have low power requirements for a light. Paired with one of the wide angle lenses, it would be pretty trick. Someday, I will do it But, I have to get my original reverse lights working first!
ive had lights on the rack facing backwards...i moved them to the bumper.
simply put, if youre using them to back up, and not as for something like lighting up a campsite, put them low.
at least this has worked best for me....i actually use them almost every time i back up, and its amazing how much they help (two hella 500's)
I have added some driving lights to the rear bumper of my first gen and I love it. they are wired into the reverse lights and only come on when I am in reverse. Super Bright and work great. They are also protected pretty well in there.
i had a set of cheap fogs mounted on my rack pointed back that were wired up to come on whenever in reverse. Functionality wise worked great but i didnt like the look of them up there and i didnt like the wire snaked thru the rear hatch seal
The logic of the wiring is not a concern for me... my plan is to use a single pole, double throw relay that allows me to have normally on via the reversing lights or manually on.
I agree on how to get the power to the lights and I am working on something creative.
Hella do some really nice flush mount lamps that I could easily set into my rear bumper. Its chrome and kind of ropey anyway so I have no issues cutting holes in it.
I also agree that under the bumper may not last too long.
I like the LED idea as you could in theory mount some into the License plate frame.
David
David
One thing:
The Luxeon V portables (120 lumens) are quoted at 500hrs lifetime, while the Luxeon III (90 lumen I think) is quoted at 100,000hrs! i'd probably go for the III looking at that, maybe even use 4 instead of 2...
Location: Houston (home), Atlanta (school), Cincinnati (work)
if you look at my pics in my sig, youll see my back-up lights. i bought them from walmart so they were like $10 each. i used 16 gauge wire that i already ahd and the whole project was pretty cheap. some people may think in the location i have them in (hanging from the bumper), they would get ripped off when wheeling, however, if i go deep enough to hit those, i will have already hit my spare and my trailer hitch by a long run. if i do in fact hit them, they swivel forward and back to they should avoid damage. if i do damage them, then to walmart i go to replace a $10 light.
i wired them into a SPDT toggle with a relay i bought from radio shack. the UP position has them come on automatically when i shift into reverse (along with my stock reverse lights). the MIDDLE/OFF position turns them (and my stock reverse lights) off completely regardless. the DOWN position turns on the aux. back-up lights when i want them on. great for flashing at tailgaters or lighting up the campsite. they do their job for lighting up behind me when reversing.
if you want more info ill be glad to help out
Banned - User requested
Ive been thinking about getting these KC Lights the last ones down, they wire right into the reverse light wires, Ill get them after I retint the windows, looks like they would fit perfect on the Yakima rack
I have done exactly this.
I wired up the KC lights mentioned before to the rear of a rack on the roof. I used a 3-position switch up front in the center console, I wired the lights to either be off always, always on, or on when the headlights have been turned on and I am reversing. With these 3 options you have the best of every world. They turn on automatically at night when it's dark and you're reversing, on when you need them, or not on at all.
I ran 4 gauge wire along the drivers side, and put a distribution plate velcro'd to the body of the truck behind the rear driver's side panel, this gave me power to all the electronics & lights I have setup back there. Several 8 gauge wires run to each accessory as needed. You can then ground each powered device wherever it ends up being.
I cut holes for my back up lights on my 4Runner. Worked great for me, but now that I'm used to having a back up sensor you might want to look into one of those also/instead. It takes a bit more of the guess work out of it but you use the use of the hight mount lights while camping. Just an idea!
Seems to be a descent deal but my truck came with them so I am no expert: Click Here
The setup I had on my 4R:
i just bought some lights from wally's ($15) and want to know if i splice them into my reverse lights AND run them to the switch they came with, i should be good to go right?
they will come on when in reverse or whenever i turn the switch on right?
if the switch is off, and i put into reverse, will the lights come on since they are also spliced into the stock reverse lights?
i am trying to keep it simple! just need to know if it will work that way
no... they won't
edit: well, they could.... (I read it wrong at first, i think)
here's how it should be done... wire from reverse with a diode inline goes to a relay, a wire with the switch inline goes from (ACC or somewhere) to the same place on the relay...
the relay is to prevent overloading your reverse lighting circuit
the diode is to prevent damage to your reverse wiring circuit when you flip the lights on with the switch
http://ovo.ca/wiring/wiring.html has some info, and heres a diagram i made a while ago....
in his write up, he said that when in the off possition even his reverse lights dont operate! i would prefer to just make it to where there on all the time when in reverse as your only in reverse a few sec. plus, the kit came with a switch.
