Automatic Transmission downshifting clunk. - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 11-11-2007, 05:13 PM   #1
Question Automatic Transmission downshifting clunk.
I am just wandering if anyone else has the same issue, here is what I have:
When I am stopping my truck in a steadily firm rate (not an emergency stop, but not an easy one either) I can hear a feel a ?clunk? that coming from the transmission area.
I think I am hearing downshifting from second to first gear. This only happens when transmission is cold, after it warms up this problem completely goes away.
Also if I am easy on the brake and slow down gradually there is no clunk, even when transmission is cold.
Other than that transmission perform flawlessly, including times when I am towing a boat trailer.
Info about my truck: 1996 4Runner 4x4, 3.4L, Auto. Truck has 102 K on it.
Transmission filter was cleaned when it had about 65K, transmission oil was changed by draining and adding around 4.5 Q every 25K.
Any thoughts and recommendations are appreciated.
progress4m is offline   Reply With Quote
Old 11-11-2007, 05:38 PM   #2
bwhyit's Avatar
Probably the driveshaft splines in your tranny sticking and then breaking loose when the weight of the vehicle come down in the rear. Pretty common problem. I have a 98 4runner and mine does it. If it bothers you then take out the driveshaft and clean and lube the yoke splines.
bwhyit is offline   Reply With Quote
Old 11-11-2007, 06:10 PM   #3
That is the driveshaft telling you it is time to lube. Get under there and lube all 5000 zerk fittings.
Wife's 4runner is offline   Reply With Quote
Old 11-11-2007, 06:45 PM   #4
MTL_4runner's Avatar
MTL_4runner is offline   Reply With Quote
Old 11-11-2007, 07:41 PM   #5
Thank you for all your responses!
So you think it is a driveshaft not a transmission??
My fear was that is a transmission?I hope I was wrong.
I am hearing this clunk while truck still in motion going about 5-10 mph, what I am trying to say is that this is not a typical (for 4 Runners that needs yoke lubrication) thud that you can hear in the rear when you come to complete stop and then release your break?
Any way? I do lubricate driveshaft regularly but I will do it again, I hoping that clunk will go away.
I will keep my fingers crossed and post the results.
Thanks again!
FS[PacSouthWest]: FS: A340 transmission and t/case Lancaster Ca 4x4-runner Engines - Transmissions 4 12-27-2016 02:58 PM
FS[SouthEast]: BudBuilt Cross-member, Warn Fairlead, Autopal Lights, 4Runner Console,OEM Skid Plate BeMiceElf Misc Stuff (Vehicle Related) 7 10-10-2015 10:40 PM
Tranny/Transfer case questions eggens 86-95 Trucks & 4Runners 3 09-05-2015 01:16 AM
I want to swap 3rd gen 4runner transmissions bu need accurate wiring diagrams kelly1450 95.5-2004 Tacomas & 96-2002 4Runners 1 09-02-2015 01:29 PM
A340H Park/Neutral Switch Inter-Year Compatibilty Hugh_Mann 86-95 Trucks & 4Runners 4 08-31-2015 05:02 AM
Tags
2004, 4runner, auto, automatic, braking, clunk, clunking, clunks, downshift, downshifting, grade, shifting, slowing, toyota, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
