auto trans i need help!
ok so i have had this recent problem and i have looked through lots of threads and cant seem to find any about the problem i am having. ok so its kind of hard to describe but when im driving at highway speeds and i get to an uphill part of the road my trans seems to slip momentarily then catch this will happen 2-3 times until i speed up a bit and i cant seem to pinpoint what would cause this so any suggestions would help
thanks in advance
thanks in advance
yeah the truck is exactly whats in my sig checked my trans fluid right when it happened the first time and everything seems fine... and i dont think its the strawberry milkshake because im not getting any over heating temp is right in the center the whole time... could it still be?
Sure its not low on fluid? Slipping on an uphill seems to me like its a lil low on fluid. You know you have to check trans fluid with the vechile at operating temp and running.
What gears are you running? Seems pretty normal to me when running oversized tires on stock gears unless you have 4.56 gears. I run 4.10 gears with 285/75/16 and it seems like it slips going up hill sometimes.
D.B.T. 87 4x4
07-20-2015 04:51 PM
