auto trans flush
auto trans flush
so my auto trans in my 5vzfe was shifting a bit rough so i checked my trans fluid and it was low, brown, and smelled burnt so i went to napa and bought a trans flush kit came with a new filter and gasket so i drained the trans pulled the pan and and replaced the filter and filled with 5 1/2 qts of trans fluid and seems to be shifting a lot smoother. when i checked the magnets on the bottom of the pan there seemed to be a bit of metal on them so i was just wondering if anyone knew what to look for to see if it will be okay. or if it is already toasted thanks in advance! btw my truck is the one in the sig
A coating of metallic paste is normal for the magnets, big pieces is not good. Just clean them off when you have the pan off and put them back where they were or look at the FSM for magnet positions.
Now perform a complete flush of 12+ qts when you have the time and $$$.
http://home.centurytel.net/stevenjac...sh/tranny.html
Well I dropped my Statistics elective and took Gas Power instead but I believe the 2nd D&F you would have about 75% of the ATF changed.
Some say you shouldn't even change it at all once you burn a good coating of varnish inside the tranny, so maybe just 1 or 2 D&F would be enough. That being said, I'd probably do a full flush myself. Confused yet?
Mt. Goat, now you have me confused.
I guess T. Boone didn't teach you that Gas Power class at OSU.
I've done full flushes on my transmissions for 15 years. Other than a regular filter change, I've never had to touch any of them for major service, even for the POS Ford used A4LD....
Your experience is comforting to those of us that keep the ATF nice and fresh. Hope I have the same results, I also have a Fix Or Replace Daily (FORD) 95 Taurus.
I have little faith that doing a 12-qt flush using the cooler lines is changing more than 50% of the transmission fluid. There are many places in the valve body and a large majority of the torque converter that simply aren't exchanging fluid very quickly, if at all.
Dan
Dan
D.B.T. 87 4x4
07-20-2015 04:51 PM
