auto tranny question
Old 03-29-2005, 07:39 AM
az4x4runner's Avatar
If a vehicle is moving at low speeds (~25 mph) and the shifter is bumped into neutral is this bad for an a/t? Should the vehicle come to a stop before putting it back in drive?
I've had people bump mine into N before, and I've always wondered if it's damaging to put it back in drive while moving...
Thanks
Old 03-29-2005, 12:20 PM
I guess nobody knows?
Old 03-29-2005, 12:38 PM
hiloracerboy84's Avatar
pretty sure that it does no harm to your engine/tranny
Old 03-29-2005, 12:44 PM
YotaDoubleCab's Avatar
It is perfectly safe, just give it a second to shift into gear before you get back on the gas
Old 03-29-2005, 02:16 PM
Flamedx4's Avatar
No harm at all. Just avoid shifting into R when you're still moving forward, etc..
What are you doing that you would bump the shifter?
Old 03-29-2005, 03:00 PM
Robinhood150's Avatar
My friend did that...on the freeway! He said it went into gear. His truck seemed to be OK.
Old 03-29-2005, 09:03 PM
TechWrench's Avatar
Thanks
'Bumping' the gearshift lever into neutral while moving should not damage an auto transmission. And you can put it back into drive without any problem. But, if you let the engine either rev up too high, or drop to an idle, there will be a 'bump' when the engine adjusts to match vehicle speed.
Old 03-30-2005, 05:45 PM
SD70MAC's Avatar
You definately don't want to put it into either R or P while driving, but it is perfectly fine to shift it into N and D while driving. Also, don't shift into 1 while going 80 mph, your pistons will try to escape from the engine block (and may succeed).
Old 03-30-2005, 05:50 PM
I just re-read my post and it sounds like I'm saying it's fine to put it into reverse. I meant that my friend was an idiot.
Old 03-30-2005, 06:08 PM
Thanks for the replies guys. After owning one car with auto tranny problems I guess I am just a bit paranoid.
I'm not usualy doing anything.
06-01-2021 01:51 PM
Iceman4193
07-15-2015 04:48 PM
KBar
07-13-2015 06:01 PM
madxman21
07-09-2015 10:26 AM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: auto tranny question
