| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Aren't the dash lights and trailer lights supposed to work??
#2 (permalink) |
Staff
fuses for 100% sure
which means its prolly going to do it again....something isn't wired right
__________________
Tacoma miniheader install kit Now available! Click here for ordering information Need that hard to find part? Nix99 Used Toyota and Lexus parts! |
#3 (permalink) |
It might be a fuse but i realized i can't pull them while i am flushing my raditor.
So that will be tomorrow. Why would a fuse go out for the speed and tach lights only? wouldn't they all be together? and would the trailer lights be connected to it? One thing after talking to the other guy that was helping me we found out was that the running lights did indeed work at first but the blinkers only half worked. Now the blinkers work great but no running lights. I will pull the fuses to Tomorrow and see what i find. PLEASE PLEASE LET IS BE A FUSE! I don't have time to take apart the dash before i go! |
#4 (permalink) |
The running lights were the first to go when my converter went bad!
__________________
'99 SR5 Sport - Desert Dune: AirRaid MIT, OEM Air Filter, Toyo 265/75/16 ATs, Deckplate, PP Springs and Bilsteins, Cheapo nerf bars, Injector replacement impending |
#6 (permalink) | |
Quote:
You have blown a fuse for sure....what caused it is another story. The instrument panel lights are on the same fuse as the running lights. Judging from what you said about the blinkers only half working....you may have a bad bulb somewhere. Blinkers can act very strange if one element is burned out and the others are working. That bulb might even have a relationship to the fuse blowing once the trailer was hooked up. I would check the fuses first. Unhook the trailer and make sure ALL blinkers, running lights, blinkers with running lights, and brakes are working correctly. If they are, I would then check the trailer wiring harness on the truck...make sure the wire is intact...then do the same on the trailer. Often the wires get scraped and may be shorting somewhere. Then check all the bulbs on the trailer. Also you might try the trailer on another vehicle if you have one with a trailer hookup. I had an issue with mine one time, I was thinking it was the 4runner, turned out the trailer was wired wrong and had a bad bulb. Good Luck
__________________
DMN, D.D.S. "DOC" 2000 4Runner SR5 4WD- RADIANT RED, Toyota E-Locker, BFG AT's, Yakima Rocket Box, Toyota Ski Rack, Alpine Amp, iPhone interface, Focal 6.5" Components Front & REAR!, Monster Wiring, Husky Liners, Magellan Color GPS, Bilstein Sucks...I mean Shocks 2005 Sequoia SR5 4WD- BRILLIANT WHITE, Yakima RB, Husky Liners, 10.4" LCD/DVD Player, iPod interface, BFG AT's 1986 Jeep CJ-7- Hard & Soft Tops, Alpine CD, iPod interface, Polk Speakers, 31" BFG AT's, Bosch Lights, Mopar MPI |
#7 (permalink) |
I had issues with my 02 and the towing lights. Check the area that the plug that connects all the lights togethr. (drivers side rear near the bumper). Mine wasnt getting full contact and that might be causing your to short out. Worth a shot and hope you get it fixed
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| headlights work, but NO tail, licenceplate, dash, or corner lights | 85Froder | 84-85 Trucks & 4Runners | 5 | 12-20-2006 03:59 PM |
| front running lights and dash lights | 4runnin2 | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 06-13-2006 06:51 PM |
| Dash lights dont work | zombi | 86-95 Trucks & 4Runners | 8 | 05-21-2006 08:58 PM |
| dash lights, marker lights and taillights dont work | nbrooks | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 03-24-2005 03:25 PM |
