ARB Locker, 4.88s & Compressor - DONE!
Man what a pita swapping a front diff is. The rear was so much easier. The hardest part was getting the diff out. Putting the new one in was easy(er). All in all everything went well and no busted knuckles which was a plus lol
Temp pre-runner lol
Then it was on to installing the compressor. With absolutely no place to put it, I decided next to th battery was the only solution. So I bought a metal plate to go from under the battery and extend out in the open area. Put an L bracket to extend the support, painted and bolted it all down. Works very well. Glad to be have this project done. Next will be 4.88s for the rear.
Temp pre-runner lol
Good luck! Save up your mulah haha.
The pic shows the missing diff. Steering rack was left alone. The only thing that makes the diff difficult in getting out is the bolt that sticks down from the diff into the cross member as well as the pinion flange because it hits the bell housing. I finally said screw it and removed the flange to get it out. It's just a pain cus you have to lift up and wiggle it out. It's not light by any means.
More than I'd like to admit lol
TheBFA
02-15-2020 06:55 AM
JookUpVandetti
09-30-2015 08:58 AM
Toys4parts
09-26-2015 01:56 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
