ARB Compressor wiring
Two questions:
- for the Blu-Wht wire from switch #1, the diagram says "to dash illumination"...what is the purpose of this wire? the compressor is running without it.
- did you use loctite on the threads of the nipples when you installed them on the compressor per the ARB instructions?
Originally Posted by RTdawgs
Two questions:
I used pipe dope and they leaked. Then I used teflon tape and no problems.
I will go look. I am almost sure I used on of the wires off the stereo........I am sure it was the factory wire used for the factory deck. I'll go look.
I have it attached to the ''positive dimmer'' (org/wht wire) wire that is coming off the harness I bought to install my new stereo (didn't want to cut wires and void warranty). Since I don't have the factory deck anymore and my new deck doesn't use the dimmer wire I figured I would give it a try and it works.
skoti89
07-08-2015 12:05 AM
2001, arb, compressor, compressors, diagram, diagrams, directions, installed, manual, pictures, switch, tacoma, tacomas, wire, wiring
