Aquamist high-speed valve question
Where are you guys putting the high-speed valve for the WI? Should it be as close as possible to the throttle body or does it matter? Gadget's instructions just say to find a suitable location.
It doesn't really matter... Some place that makes sense, and where the hoses will be exposed to minimal heat.
Are you running a URD tank? If so, then the AM pump fits right on it, and you can put the valve down there too. That'll keep it out of the heat. I have a LOT of heat under my hood and I blow that plastic line all the time.
(when did you get an AM system? hmmm... )
http://community.webshots.com/photo/...42310107eFPupB
http://community.webshots.com/photo/...42310107KrwChB
http://community.webshots.com/photo/...42310107HpjsWy
Thanks, you better get going Mark
I got an answer from Gadget over on CT: http://www.customtacos.com/forum/showthread.php?t=69130
Originally Posted by Gadget
The closer to the nozzle the better, but you have to work around a good installation location also. Behind the brake booster I would think is way to far away. I would make every effort to keep it no longer then 6".
the1998sr5
15
07-14-2020 08:35 PM
