APEXi SAFII install on a '2000, 3.4L Runner
Old 12-18-2004, 06:18 AM
bosco659's Avatar
Does anybody have a wiring diagram that will give me a shortcut to installing an Apexi SAFCII in my 3.4L '2000 Runner. I have the factory wiring diagrams and could probably figure it out with some studying but I thought I'd try the lazy man's route first .
So.... has anyone installed this fuel management device and recorded which wire to hook up to on the ECU?
Thanks,
Vic
Old 12-22-2004, 03:57 PM
Bigblock's Avatar
What is an Apexi SAFCII? And where are the instructions?
Old 11-05-2006, 08:18 PM
BUZY's Avatar
safc II
i'm trying to install the same mod on my '00 4runner. can't figure out the wiring diagram. anyone with a solution?
Old 11-05-2006, 08:32 PM
KyleT's Avatar
ApexI super air flow controller 2. modifies the signal from the engine to the ecu to trick the ecu into adding or subtracting fuel and ignition (if it is setup to change ignition) A PIGGY BACK ecu.
Old 12-09-2006, 10:53 PM
BUZY's Avatar
safc
are there anyone can help me in installing safc for my '00 4runner?
Old 12-10-2006, 06:16 AM
Greedy's Avatar
what do you need to splice into? MAF, 02, RPM, Knock sensor?
Old 01-19-2007, 04:46 PM
BUZY's Avatar
safc
need to splice into power, rpm, knocking, throttle, ground, airflow/pressure signal output and input, and if the ecu is a hot wire/flap/pressure sensor or karman type frequency sensor.
Old 01-19-2007, 06:50 PM
bosco659's Avatar
BUZY, if you send me your email address I can scan and send you the wiring diagram that you need next week.. Send it to me in my PM.
Vic
toyota32
07-06-2015 05:42 PM
CJ94yota
07-03-2015 10:14 PM
ACZR
06-23-2015 07:55 PM
Schif
06-20-2015 08:39 PM
Quick Reply: APEXi SAFII install on a '2000, 3.4L Runner
