anything look strange here?
Old 03-15-2007, 04:12 PM
redlobster's Avatar
first pic is the passenger side, second and third pic is the drivers side
im gonna have to assume i drove home all the way from minnesota like this and have been daily driving it like this,
Old 03-15-2007, 04:14 PM
BajaRunner's Avatar
No, everything looks completely normal.
Old 03-15-2007, 04:16 PM
redlobster's Avatar
new sway bar bushings are needed i assume? should i get the ones from wheelers off road for 23.95?
is it safe to drive like this also? i assume so since it appears to just be the sway bar unhooked on one side
Old 03-15-2007, 04:19 PM
Co-Founder/Administrator
Staff
Corey's Avatar
Looks to me also like the first pic is the drivers side, and the second two are the passenger side, just the opposite of what you said.
Unless of course my brain is running backwards, I have been up a long time.
Old 03-15-2007, 04:20 PM
da_bigg_wigg's Avatar
Just a lil more tilty is all
wjwerdna's Avatar
you need new bushings AND new links, that one is broken, it snapped between the top and bottom bushing
but no, it doesnt look strange, only stock
edit: now I see what is strange, sorry it took so long, yeah your CV angles are perfectly stock and you have no lift
Old 03-15-2007, 04:22 PM
wjwerdna's Avatar
yep, sorry to say, it is
looks like they were taken from underneath the 4runner, not from the front, notice how the sway bar is in the FRONT, of everything... mine mounts to the frame behind the engine
Old 03-15-2007, 04:25 PM
BajaRunner's Avatar
FJ swaybars are in the front, and 3rd gens are in the rear.
Old 03-15-2007, 04:26 PM
Staff
Corey's Avatar
Oh, OK, so the pics were taken like from underneath and standing behind.
I am still not use to these front ends with rack & pinion, I would have to run out and look at mine, which is similar.
I guess the shocks/coils would be in the front.
My brain is still use to old school like my what was on my '91 4Runner.
Old 03-15-2007, 04:28 PM
midiwall's Avatar
Good time to put in disco's.
fwiw, I've been driving without a front sway bar for quite a while. The worst thing about your situation is that the link will be bashing into the bar potentially bending it (the link).
Old 03-15-2007, 04:39 PM
profuse007's Avatar
torsion bar(sp?) link is broken, of course.
Old 03-15-2007, 04:42 PM
redlobster's Avatar
somebodys a comedian i see , no lift here, my wife is gonna use it for our dd while im away for air force stuff .
where should i look for new links?
and sorry for the confusion the pics were taken from while on my back under the middle of the 4runner looking towards the frontend
Old 03-15-2007, 04:50 PM
midiwall's Avatar
If you're thinking disco's...
http://www.wabfab.org/96024Runner/96...uickdiscos.htm
Old 03-15-2007, 05:01 PM
wjwerdna's Avatar
if you want the same crazy balljoint using stock one, I would recommend one of the dealerships that cater to us here... I have had good service from Northridge Toyota
Old 03-15-2007, 05:02 PM
redlobster's Avatar
just looking for something stock,
from rockauto.com , not sure if web link will work
HLC Part # 48820AD010A {Front Stabilizer Link: Left & Right #48820AD010}
http://www.rockauto.com/catalog/x,ca...k,partGroup,27
Old 03-15-2007, 05:08 PM
Bigblock's Avatar
Lady driver-fix it!You driving-take it all out;you wont miss it!
Old 03-15-2007, 05:17 PM
Ringmaster's Avatar
Looks to me like your well on your way just to remove the swaybar completely.
A few more bolts, and it's in the dumpster.
Old 03-15-2007, 05:20 PM
wjwerdna's Avatar
seems too inexpensive to be right when compared to the moog parts... they are good quality also.. but not listed in right parts either
Old 03-15-2007, 05:51 PM
toyotaoffroad91's Avatar
cool new sway bar disco's!!
Old 04-10-2007, 04:16 PM
redlobster's Avatar
I got the new endlink from toyota, I just recieved the bushing kit from wheelers offroad, seeing as the one link is broken doesnt have the remaining nuts and possibly washers ,how do i find out which ones i need as the link from toyota and the wheelers kit neither came with new washers or nuts.
Quick Reply: anything look strange here?
