Anything Else off Truck?
I am almost done getting rid of stuff off my parts truck 87 and shipping it to the junk yard.
Is there anything small I may have missed that I should get? I hear you can do differential breathers with some parts from pickups? Just throw it out there so I dont forget somehting and regret it.
Thanks,
Alex
Thanks,
Alex
"There is a fitting on the Toyota 4 cylinder intake manifold that will serve this purpose well, but if you have to buy the fitting new, there is a cheaper alternative."
From a 4x4wire.com writeup. What part is that, it does not specify.
Thanks
Thanks
Not exactly the help you need but it may keep you from worrying over this one....
I got Toyota PN 90930-03136 from my local dealer (www.toyota-parts.com) for less than 3 bucks. Its the same breather as what is in the diff except its got a hose fitting on it and not a threaded fitting.
All you need to do then is pop the top off the stock breather (the sheet metal cap) and run a hose (with clamps on both ends..) from the origingal diff breather to your new breather.
duckhead
170
11-13-2017 06:07 AM
Crazy_Guy97
12
06-24-2015 04:02 PM
