Anyone using Optima Yellow Top w/ reverse post?
Old 06-07-2004, 09:07 AM
Ranski's Avatar
If so do you have the model number, I can't seem to find it on their website.
Also, in my forum search I did run across one post that mentioned the reverse post YT doesn't have enough cranking amps to start 4Runners...is this true?
Old 06-07-2004, 11:51 AM
Bigkahuna808's Avatar
Im running the blue top. The yellow wasnt good enough for my system. To meet the needs of the extened posts. I cut off the orginal negative terminal, and replaced it with a mupltiple ground extened terminal. And the power end I jist cut one of the body clips off that held it in place.
Optima batterys rule!!!!
justdifferentials
Just Differentials
06-13-2022 07:40 PM
justdifferentials
14
06-11-2017 08:36 PM
pickle6415
12-25-2015 07:34 PM
IntoTheVoid
10-24-2015 04:54 PM
Quick Reply: Anyone using Optima Yellow Top w/ reverse post?
