Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
anyone running a chevy engine?
Hey guys, I was just wondering if anyone here is running a small block chevy or a 4.3. If so, what are the advantages/disadvantages to it? Also, how easy is it to do the swap.I'm actually considering dumping the 3.4 swap to do the 350 swap. All depending on whether or not I get something particular in the next couple days
__________________
'91 4Runner 22RE 4x4 project rock crawler...on hold '93 4Runner daily driver...Current project, almost completed 1uz Lexus v8 swap. |
| Sponsored Links |
#2 (permalink) |
do a search. there plenty of info on it
#3 (permalink) | |
Quote:
__________________
#4 (permalink) |
i know i've seen a first gen or two with a chevy engine. can't remember if those guys are on this board tho, they may be on 4x4 wire
__________________
[2002 4Runner 4WD] |
#5 (permalink) |
I am going to drop the chevy 4.3 in this summer, if i can get some cash.
#6 (permalink) |
off topic, but either way you go,can i help? haha.
#7 (permalink) |
terky -
if you live in everett mass than there is some kid in my town selling an 91 blazer with teh 4.3 in it for 500 complete, its got 120k but only problem is bad gas tank. Just let me know if you are from the area. |
#8 (permalink) | |
Quote:
__________________
#9 (permalink) |
I'm working on getting the cash together for a 4.3 and NV4500 5spd swap, probably do it in about a year or so. I like the 4.3 cause you can still squeeze a lot of power out of em, and they aren't as tight a fit as a full small block. I've heard that with a small block you might need to modify your firewall, and radiator core cause of the length of it. Plus I found a 4.3 short block for $50 that I can rebuild. I can get about 280 hp and 330 ft.lbs. the way I want to build it. Thats what I figure.
__________________
1989 pickup, 4x4, 22re 4" superlift (full rear springs, skidplate), dual steering stabilizer, downey 26mm torstion bars, 1.5" rear shackles, low profile bumpstops, 5.29's w/ V6 3rd, 35x12.5 BFG MT's on AR Outlaw II 15x10's, 2" wheel spacers, custom exhaust (pacesetter header, 2.25" single in/dual out flowmaster delta 40) custom built 3" intake with stock replacement K&N, LCE water pump, flex-a-lite fan, optima red top My truck site |
#10 (permalink) | |
Quote:
__________________
#11 (permalink) | |
Quote:
#12 (permalink) |
here you go.. this thing is seriously awesome.....
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
__________________
'91 4Runner 22RE 4x4 project rock crawler...on hold '93 4Runner daily driver...Current project, almost completed 1uz Lexus v8 swap. Last edited by blackrunner91 : 04-29-2004 at 08:40 PM. Reason: oops |
#13 (permalink) |
The only big problem is that NV4500 is so freakin' expensive to buy and to adapt but I think they're worth it. You're right about the 4.3. It is just a 350 minus 2 cylinders. Thats a good thing cause from what I know, all the parts (except for the lengthwise parts) are interchangable, which makes it a little cheaper.
__________________
#14 (permalink) |
i'd say just get a cheap t18 or sm465 and run steeper gears in the rear end. might not be able to hotrod as much though with only 3 practical street gears
both trannies are cheaper than dirt though
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts past toys: 1984 4x2 1979 4x4 1991 4x4 |
#15 (permalink) |
I can totally understand the cheapness of those trannies. But I'm already running 5.29's and it don't get much steaper than that. I want the low first gear from the NV4500 (6.31 or 5.61, depending on year). To me its worth it for what I want to do. I'm a torque junky!
Does anybody know how to Identify the NV4500 from the others if I was to find one in a junkyard or something?
__________________
#16 (permalink) |
i believe the t18 has a 6.xx low gear and the 465 has a 6xx or 7xx low if that's what you're getting at. only problem is that you don't get overdrive for those steep gears that you have
__________________
#17 (permalink) |
The overdrive would be nice to have. I want my truck to be stout but I've also got to drive it everyday and on the interstate too. To me the 4500 seems to be a good all around tranny.
Oops, I think I robbed this other dude's (blackerunner91) thread. Didn't mean to, my bad.
__________________
#18 (permalink) |
I'm perfectly happy with my 7.05:1 first gear and no overdrive. If I want an overdrive, it can be added to my tranny ($$$ though). I run 4.11 rear gears and won't even consider anything lower unless I consider the truck a dedicated trailer-queen. For tranny identification, Novak has a good page here. Novak specializes in Jeep conversions, but the information is valuable for any engine tranny swap.
__________________
Dave '84 XCab, blown 283 V8, SM420, dual cases, etc. -For Sale '01 Subaru Outback |
#19 (permalink) |
What vehicles came/come with the NV4500? Nice 4-Runner on Ebay BTW.
__________________
Chris Mine-94 SR5 4-Runner, 3.0, 4X4, Aisin Hubs, Yakima Load Warrior, 210k Miles | Wifes-99 Limited |
#20 (permalink) |
'93-94 chevy 1 ton and I think 3/4 ton with the 6.3 first gear. '95-present chevy and dodge 1 ton and again I think 3/4 ton with the 5.61 first gear.
__________________
| Display Modes | |
