Anyone with a hood channel CB anatenna mount? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-11-2003, 08:37 PM   #1 (permalink)
TDiddy's Avatar
Send a message via AIM to TDiddy Send a message via Yahoo to TDiddy
Anyone with a hood channel CB antenna mount?
I was looking over potential spots along the hood channel in preparation for installing my new CB and antenna mount tomorrow. I ordered a hood channel mount, similar to the one HBoss uses. Problem is, the hood seems to rub the bracket no matter where I test is out (on the drivers side at least).
Has anyone else had a similar problem? I'm going to try the mount on the passenger side tomorrow. But is SWR inherently better on the driver side or do you think it doesn't matter which side I use?
Tom
TDiddy is offline
Old 01-11-2003, 09:31 PM   #2 (permalink)
BajaTaco's Avatar
I can relate
Yep - I have the hood mount too, and it rubs a little bit. I just plan to grind it down a little bit - no biggie. If your radio antenna is on the pass. side, then you would probably be better off mounting it on the driver's side.
__________________
Chris Marzonie
BAJATACO.COM
Toyota light expedition vehicle
Adventure reports
Lots of Photos
OVERLAND JOURNAL
North America's first vehicle-dependent expedition magazine
BajaTaco is offline
Old 01-11-2003, 10:04 PM   #3 (permalink)
Co-Founder/Administrator
Staff
Corey's Avatar
I have pics of my old setup on my CB page listed on my homepage.
It did not rub, but it was a close fit.
Corey is offline
Old 01-11-2003, 10:20 PM   #4 (permalink)
You might check your hood to see if it is closer to the fender on the drivers side than the passenger side. When I was mounting my bracket (made to fit Toyotas), one of the CB place people said I might have to loosen the hood mounting bolts a bit and shift it a little toward the other side. I managed to fit mine without any hood moving (as Corey said, its close), so I haven't actually tried it. I think I'd be careful not to loosen things much though.
You do have to put the bracket so the offset (where the two bends are close together) lines up with the edge of the hood/corner of the fender. There isn't enough clearance to just have the bracket come straight up through the gap anywhere you choose. On mine, that limited me to one place, and I don't think the bracket would even work on the other side because of the angle of the bends.
I haven't noticed any obvious rubbing, but I wonder if there is enough hood/body movement to wear paint away over time.
Alan
alanh is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
CB anatenna mount (FJC) Corey FJ Cruiser 2 04-26-2006 09:01 PM
CB ANTENNA hood mount bracket. Whick one? fadetoblack72 GPS & Communication 4 04-10-2005 12:21 PM
where should i mount my cb? jtm994 GPS & Communication 6 12-26-2004 12:46 PM
CB Antenna - Hood Channel Mounts TDiddy 95.5-2004 Tacomas & 96-2002 4Runners 2 03-13-2004 09:57 AM
CB Channel Question HBoss 95.5-2004 Tacomas & 96-2002 4Runners 5 07-15-2002 05:30 AM
2009 InternetBrands, Inc.
