anyone grease spindle bushings as maintenance?
Old 07-14-2003, 06:25 PM
hellas's Avatar
it seems a little extreme to remove the knuckle every 30K to regrease them
any of you 2geners normally grease them?
Old 07-14-2003, 10:18 PM
jimrockford's Avatar
It seems extreme to me too. If you had that done at a dealership, you'd be looking at several hundred dollars. And, in the end, you're really only protecting about $90 worth of parts.
I would just leave them alone and replace them if they go bad. If you've got the right tools, it can be a do it yourself job. I replaced mine recently, but had access to a shop with a lift and hydraulic press.
From my research, I found that the bushings Toyota used are prone to failure. Dealerships have begun replacing them with a needle bearing/thrust bushing combo that they claim lasts longer. I did a write up on my install if you want to take a look at it:
Steering Spindle Bushing Replacement
Old 07-15-2003, 09:45 AM
hellas's Avatar
exactly what i was thinking. i read your write up. just looked over my bills and the dealer changed mine to the needle bearings 3 years ago
thanks!
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
live4soccer7
05-11-2016 06:52 PM
punks_is_4x4
02-26-2016 04:29 PM
Truckwithoutaname
10-03-2015 03:41 PM
Quick Reply: anyone grease spindle bushings as maintenance?
