anti-rattle springs - how many per caliper?
Old 09-24-2007, 05:54 AM
MadCityRich's Avatar
I've been getting a metallic "clank!" when going over short bumps (like expansion heaves or cracks). After using the scientific method this weekend, I tracked down the problem to my brakes. I also discovered that I'd put on the anti rattle springs slightly wrong. Correcting them improved, but didn't solve the problem.
I recently installed 199mm Tundra brakes on my '02 4Runner. My old brakes only had a single anti-rattle spring at the top of the brake pads. I installed the Tundra brakes with a single anti-rattle spring at the top of the brake pads.
Would there be anything wrong with adding a second anti-rattle spring to the bottom of the pads? Is there supposed to be a second spring?
Thanks much,
MadCityRich
Old 09-24-2007, 06:02 AM
Fingers's Avatar
Same problem, only worse I'm missing the spring from one side entirely. Truck sounds like it's comming apart over any rough terrain unless you put some pressure on the brake. How does one get the spring without buying a new caliper or pad set?
Old 09-24-2007, 06:57 AM
I think your best bet is at the dealership. I can't find any online retailers that just sell the spring.
I read your message. I would expect anot-rattle springs to be common across many models of vehicle. I don't have a parts catalog, but your dealer might be able to cross reference vehicles. Are there other larger truck models sold in Japan? They probably use the same anto-rattle spring as the Tundra. It would seem crazy for Toyota to specify anti-rattle springs that are vehicle specific.
Good luck,
MadCityRich
Old 09-29-2007, 04:46 AM
MTL_4runner's Avatar
The answer is no and a second clip is not necessary.
This is what it should look like assembled:
http://www.ultimateyota.com/index.ph...18407#msg18407
Old 09-29-2007, 06:39 AM
netwt12's Avatar
what you need is a front disc brake hardware kit a local parts store should have it. for an 01 Tundra the Carquest part # H15781. even if you dont have a carquest in your area any parts store should be able to cross the number.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
stanz
10-30-2015 10:33 AM
user 82300
09-22-2015 07:00 AM
user 82300
09-15-2015 05:49 AM
Quick Reply: anti-rattle springs - how many per caliper?
