Another Overdrive Problem
I have the dreaded "won't shift into Overdrive" issue. Here are the particulars:
97 4runner, 3.4L 5ZE 4WD
1. Problem is ambient temperature dependent - it shifts into Overdrive when the outside temperature is over 80 degrees
2. It takes 40 miles on the highway for the transmission to shift into Overdrive - this happens at any outside temperature.
3. Sometimes it will kick in when the cruise control is engaged when the outside temperature is warm (80 degrees +).
Here's what I've done so far (as per the threads on this site):
1. Changed thermostat
2. Changed Coolant Sensor
3. Inspected the bypass hose - no kinks or clogs.
What should I look at next? The transmission shifts perfectly in every other gear.
Thanks in Advance.
Thanks in Advance.
Overdrive
Thanks for the reply, ninjarunner.
Should have included the fact that the fluid was changed in May in my original post...sorry.
I was driving today on the highway. After 30+ miles at highway speed, I was able to get OD engaged in two ways:
1. Turn off cruise, then turn it back on.
2. Hit the "O/D OFF" button on then off again.
The O/D will work OK after it catches the first time (for example, after stopping at a rest area and getting on the highway again, it shifts into O/D perfectly at 50 miles per hour).
Thanks for any help you can give.
Your tranny sounds like it has a memory problem. It just needs a little reminding that it has 4th gear is all.
Do you think it could be something with the linkage? like maybe you need to adjust you shifter down where it "connects" to your tranny?
Will it shift into O/D if you hit a bump at 50+ mph?
Just a thought, I had a simmiler problem, mine would go into overdrive evreytime over 30, it would only kick down after I floored it or hit the overdrive switch. The problem got fixed after I changed the plugs and wires, Like I said just a thought.
Have you checked the switch on the gear shift.
Checked
Thanks for the replies guys. Checked the linkage and switch...they look OK. Is there a temp sensor on the tranny? I thought that I read somewhere that there was. If anyone knows where it is and if it's difficult to replace...
Thanks.
Thanks.
Sounds like a solenoid problem to me, pretty common for older Toyota auto trannys. See the very end of this article: http://rigs.corequipment.com/Cebby/9...20Transtec.pdf Things as small as lint from a rag can cause problems with shift solenoids. Did this start after a tranny flush?
Here's some good pics of where the solenoids are:
http://members.cox.net/mgriese5/Level10.html
See a FSM for which shift solenoid controls the OD engagement. Here's a 03 Tacoma FSM it may be the same:
http://www.deserted1.com/FSM/
O/d
Thanks Mt. Goat.
As a matter of fact, the tranny did have a flush when I bought my 4runner from a Toyota dealer in May. I'll try looking at the O/D solenoid.
Thanks for your help. Those links are great.
Trouble Found
Thanks to everyone that replied.
For anyone that has this problem in the future, here's what fixed the issue: the cruise control actuator.
It seems that the signal to shift into overdrive goes through the actuator. If the actuator is not sending or receiving voltage properly, the overdrive solenoid will not engage.
This was proven by disconnecting the actuator then driving. The overdrive engaged perfectly every time.
After installing a used actuator (the dealership cost for a new one was $1200! Used: $160) the vehicle is running great.
Don't know, but my guess is that if it has cruise control, there should be an actuator. If you can find it and disconnect it and the tranny goes into overdrive then you had the same symptoms I had.
theking11863
03-19-2016 09:36 PM
