Another deckplate mod ???
Old 05-12-2005, 01:03 PM
ugabulldog's Avatar
Ok, newbie question here, and yes I did a search first. How do you reset the ecu after doing the deckplate mod, is this done just by pulling and reinstalling a fuse?
Old 05-12-2005, 02:03 PM
midiwall's Avatar
search: "reset ecu fuse" (no quotes)... there're a bunch of hits.
There's a fuse box under the hood, just behind the battery. Pop the top and use the legend printed on the top to find the fuse marked "EFI". Mine's the 3rd one up in the left hand column, I think your 98 will be in the same spot.
Pull that fuse, wait 20 seconds and put it back in (side note: people will tell you to wait anywhere from 5 seconds to 15 minutes. Mine clears in under 10 seconds). Put the top back on the fuse box and you're set to go.
Old 05-13-2005, 05:15 AM
MTL_4runner's Avatar
.....or you can just pull the negative battery terminal (but you'll need to reset radio stations).
Old 05-14-2005, 09:14 AM
ugabulldog's Avatar
thanks for the help. mod went smooth yesterday. I used a jigsaw and it worked fine.
TheBFA
02-15-2020 06:55 AM
punks_is_4x4
05-31-2016 06:03 AM
voiddweller
53
02-01-2016 05:46 AM
oldblue
09-28-2015 04:07 PM
Project90
09-24-2015 11:40 PM
Quick Reply: Another deckplate mod ???
