another Body Lift question, need pics
Does anyone have pics of the bolts and blocks installed on 3rd
gen 4Runners. I want to see the difference in the sizes of pucks and bolts.
Mine is a 2" but looks just like steveo.
http://community.webshots.com/album/100761002toScFk
The small blocks go up front with the longest bolts.
then use the 4 medium bolts for the middle
then use the shotest bolts for the rear.
hope this helps
hope this helps
Hypelite have you got you lift on yet, I want to see what it looks like with the 305s. I want to see if I can fit 315/75 if you have a lot of room beings we have close to the same amount of lift.
Front and rear are completly done. The bolts I have left are not quite long enough, but I put them anyway without the metal tube and compressed the factory rubber bushings underneath the mounts. Not to safe but I'll get longer ones from Fastenal monday. Also is the middle bushing shorter than the others?
06-01-2021 01:51 PM
09-04-2015 09:27 AM
skoti89
07-06-2015 07:45 PM
