Old 04-07-2016, 11:42 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Brake Guides
Print Wikipost
Another ABS VSC Off VSC Trac Brake Light Question
Old 04-23-2013, 08:12 AM
Clyby's Avatar
Smile Another ABS VSC Off VSC Trac Brake Light Question
Hello, I'm a newbie on this sight and apologize if I've missed something. But I have a 2001 4runner. I recently parked it overnight on an unlevel surface. Next morning I got the ABS, VSC Off, VSC trac, and Brake light. I've tried to research all info about this and done a lot to try to fix the issue. I've checked the parking brake switch the brake switch, the gas cap. They all seemed to be fine. I also figured out how to read the abs and vsc codes. On the abs, I originally got 22, 46, 53, 54 (from blinking abs lights). I also got VSC trac 43. The only abs code that I could determine was 22 left front wheel sensor. I cleaned that sensor and erased the codes. Now I am getting the ABS code 54 and Vsc trac code 43. I cannot find out anything about the Code 54 nor can I get it to clear. It just comes right back. Can anyone help me with this code.
Also note FYI: since the problem originally happened after parking the vehicle on unlevel ground, I tried Zero Point calibration. Everything went OK until I turned the ignition back on -- then the VSC Trac light would not go out...
Any help would be greatly appreciated!
Old 04-23-2013, 11:55 AM
Clyby's Avatar
Another bit of info (hopefully a clue) is when I clear the codes, only the VSC Off, VSC Trac, and ABS lights go out for a few seconds. The Brake light stays on always... After a few seconds the ABS light and VSC lights come on, the VSC off light does not until I shut the ignition off then back on. Then I am back to all 4 lights on with the codes previously mentioned. Any ideas?? Thanks much!
Old 04-29-2013, 07:46 AM
Clyby's Avatar
Still looking for any help or clues on this problem. It has me stumped and based on replies (or lack of) this must be a tough one. . . I have one other piece of information that may be useful. The serial number on the 4Runner starts with "J" which I think means it was actually built in Japan.
Anyway anything anyone could suggest for me to try would be greatly appreciated!
ashersullivan88yota
01-18-2022 05:37 PM
rushw
07-18-2015 01:46 PM
Sandman
07-14-2015 12:36 PM
Johntom240
7
07-13-2015 12:18 AM
87turboPA
07-12-2015 07:49 AM
Quick Reply: Another ABS VSC Off VSC Trac Brake Light Question
