Annoting brake squeal!
Old 01-08-2004, 11:09 PM
markjs's Avatar
My brakes squeal. Is there anything can be done?
Old 01-08-2004, 11:26 PM
DravisAR's Avatar
Change the pads bud
Most brake pads...hell all brake pads that I know of, have a built in "feature" that makes your brakes squeel like crazy when they are worn out/down. Thats usually the #1 culprit. #2 could be a rock or some other foreign object stuck in a caliper. If its not either, it could be a bunch of other crap that isnt the brakes. I dont know much about drum brakes...never heard of them squeeling however...its coming from the fronts right? and only at lower speeds?
Edited: just noticed your in Port Townsend...I love it up there...my grandparents have a house up on Oak Bay I visit frequently....wish I had a reason to live there
Old 01-09-2004, 07:15 PM
markjs's Avatar
The guy who owned it before me, who is family so I trust him, says that the pads are not low. I thought only chevy had that little squeal tab on the brakes to let you know its time to change. Anyway he swore the pads were good.
BTW you are correct....Its from the front and gets louder when its wet out.
Old 01-09-2004, 08:07 PM
va97runner's Avatar
How long has it been since he's changed the pads? I've never seen a definite time interval for pads to go bad....
But also, Chevy is not the only maker that has the tabs built in.
All you have to do is take a look at the pads and you'll be able to tell.
Old 01-09-2004, 09:00 PM
markjs's Avatar
I pulled the wheel off and found a nail in the tires so thats a bitch, but I'd say the brake pad is about 1/4 to 3/8 inch thick, so thats ok right?
Old 01-10-2004, 01:17 AM
zedex's Avatar
yea. Thats good. You can get some stuff that you put on the back of the pads to stop squealing.(Its the consistancy of real heavy ketchup) Its about $4 canadian. Pull the pads. Spread the stuff on the back of the pads. reinstall and your done. The stuff works really good.
Old 01-10-2004, 03:19 AM
Mossback74's Avatar
I'd say 1/4 to 3/8 is gettin close, did you check the other side too? Be sure you check all four pads. Also remember the anti-squeeee :pig: grease when you do the brakes next time
lmobeats18
08-28-2015 04:57 PM
bfmcelroy
08-18-2015 06:42 AM
AppalachianOffRoader
08-12-2015 12:55 PM
RBK
08-02-2015 11:33 AM
PlayAwhile
07-20-2015 11:36 AM
Quick Reply: Annoting brake squeal!
