Amsoil Full Flow & Bypass Filter Questions
Old 02-22-2005, 10:29 AM
Koz
Koz's Avatar
I'm planning to install a BMK-13 kit in an 05 V8 4Runner. This kit will relocate the full flow filter and add a bypass filter. My questions are;
Is there an Amsoil distributor in the house, and is there any kind of discount? I would order the kit (retail $201), oil (at least a case) and extra filters.
Has anyone installed this kit in a 03-05 V8 4Runner, if so, where did you mount it? I seen it installed in a Tundra under the battery box, but I would like to be able to change filters without going under vehicle.
Any suggestion would be appreciated.
Koz
Old 02-22-2005, 11:01 AM
Gadget's Avatar
Yep I can help you out. The best hook up I can give you is to go to my site
www.GadgetOnline.com/AMSOIL.htm and follow the links to sign yourself up as a dealer or preferred customer. Eitherway it only costs $10. Then you can order what ever you want at DEALER COST. Trust me, you will save WAY more the $10 on that filter mount...
On the AMSOIL sight is a write up of a guy installing that mount on a Tundra. It should be the same for the 4Runner or very close. Look for it.
Gadget
Old 02-22-2005, 11:05 AM
TBob's Avatar
here the write up for the one I did on a taco - if that helps.
https://www.yotatech.com/~corey/tech...msoil/tbob.htm
Old 02-22-2005, 11:29 AM
Koz
Koz's Avatar
Thanks Gents, I signed up for the preferred customer.
Koz
Old 02-22-2005, 03:31 PM
instigator's Avatar
KOZ go to www.bobistheoilguy.com for more info about bypass oil filtering. i have a frantz on the 4runner and a gulf coast 01jr on my cruiser and they do a superb job of filtering. go there and read up and get ahold of a guy named Ralph Wood, goes by that name also on the site.
Old 02-22-2005, 03:35 PM
Gadget's Avatar
The Franz filter, is that the one that uses toliet paper?
Gadget
Old 02-22-2005, 03:37 PM
FilthyRich's Avatar
Get AMSOIL, you won't be sorry
Old 02-23-2005, 12:41 PM
instigator's Avatar
Gadget
yes it is, so does the 01jr
the1998sr5
15
07-14-2020 08:35 PM
jasonty
41
12-23-2018 01:00 PM
tj884Rdlx
08-28-2015 12:04 PM
thefishguy77
07-30-2015 10:59 AM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: Amsoil Full Flow & Bypass Filter Questions
