Alternator output? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-02-2003, 10:04 AM   #1 (permalink)
Phil G's Avatar
Alternator output?
Hey, I have a '97 4Runner, and I want to upgrade my sound system. I need to know the output of my stock alternator so I will know if the amp I am looking at will draw too much power. Thanks!
__________________
1997 4Runner SR5 2WD
Sound system
Factory brush guard w/ Hella 550s
More to come later!
Phil G is offline
Old 01-02-2003, 10:14 AM   #2 (permalink)
average 60-70 amps
if I am correct it should be 60 amp
David
david in germany is offline
Old 01-02-2003, 10:29 AM   #3 (permalink)
Phil G's Avatar
Wow, that is a lot lower than i thought! A 2000 4Runner owner over at caraudioforum.com was claiming to have an output of 90 amps, and another guy 80! I guess either they are wrong or Toyota put higher output alternators in 4Runners sometime after the '97 model year.
__________________
Sound system
More to come later!
Phil G is offline
Old 01-02-2003, 11:49 AM   #4 (permalink)
PhxTRDRunner's Avatar
Send a message via AIM to PhxTRDRunner Send a message via Yahoo to PhxTRDRunner
If I'm not mistaken, the alternator could be a few different variations based on the options available with the truck. A 60 amp would be just fine if say you had a 4 cyl 5spd with no a/c, however I can easily see them being a 80 amp'er if its a 3.4L a/c and all power opts.. I can tell you that I am running about 1000 watts right now with no additions to the factory charging system, and only plan to add a Optima battery when the stocker finally lets go. If you plan on a basic stereo, or even a dual amp system, you factory alternator will probably do just fine as long as you use the correct power wire and if you go somewhat big a capacitor or two wouldn't hurt.
__________________
'00 4runner *Sold*
'94 Supra 6spd tt
'05 Tacoma Double Cab 4wd TRD Offroad
PhxTRDRunner is offline
Old 01-02-2003, 02:37 PM   #5 (permalink)
Darren's Avatar
Send a message via AIM to Darren
I had previously believed all 3rd gens have a 75 amp unit.
But now that we have about 10 different figures here, I have no idea now! :confused:
__________________
2002 4Runner
MyColorado.org (CO landscapes, destinations & trip reports)
Darren is offline
Old 01-02-2003, 02:55 PM   #6 (permalink)
rpeAMP's Avatar
Send a message via ICQ to rpeAMP Send a message via AIM to rpeAMP Send a message via Yahoo to rpeAMP
In my 92, I am running a 2 amps- 1 four channel (40x4) and a mono (200x1) with absolutely no dimming at stop lights. I believe that my alternator is smaller than the 3rd gens., so you should be fine unless you go farther above wattage wise than I have.
__________________
Preston Edwards
1992 4Runner SR5 V6 4WD (5 Spd.)
246,000 miles & counting
2" Downey coils, 32x11.5x15 BFG A/Ts, Rockcrawler Series 51 wheels, Magnaflow exhaust, Yakima roof rack, ARB bull bar, SAW Torsion bars, (4) PIAA 520s, Cobra 18 WX ST II CB w/ Firestik antenna, hp iPaq GPS
2008 Toyota 4Runner Limted 4X4
15,000 miles & counting
rpeAMP is offline
Old 01-02-2003, 08:32 PM   #7 (permalink)
Phil G's Avatar
Quote:
Thanks for that advice, that was what i needed to know! I have the 3.4L V6 also with most of the power options, and I was planning on running a JBL 1200 watt monoblock amp to a pair of 12" Alpine Type-Rs, but I will probably only use 600 of the available watts (subs wired to put a 4 ohm load on the amp) because that is all i really need, so the amp should be putting a much lighter load on the alternator compared to if I had the subs using all of the 1200 watts. But it is nice to know that I have an extra 600 watts available if i ever decide to upgrade to better subs (Its only like $80 more to get a 1200 watt amp instead of a 600 watt amp).
__________________
Sound system
More to come later!
Phil G is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
How to test a high output alternator Bumpin' Yota 86-95 Trucks & 4Runners 3 03-21-2006 10:38 AM
alternator amp output ? 85TurboRunner 95.5-2004 Tacomas & 96-2002 4Runners 14 11-25-2005 06:14 PM
Alternator Amp Output? Gerdo Maintenance & Repair Archives 0 11-06-2005 01:04 PM
New Alternator... High output... Ducky 95.5-2004 Tacomas & 96-2002 4Runners 8 12-22-2004 07:05 PM
High Output alternator install. dbikeman 95.5-2004 Tacomas & 96-2002 4Runners 13 04-14-2004 06:24 PM
2009 InternetBrands, Inc.
