Alternator going bad...
Old 07-13-2006, 03:10 PM
ssbogger's Avatar
Well first off my battery is done. I had the guy test the alternator with one of the testers they hook to the battery and it was reading like 12.4 volts. He said it should be up around 14 somewhere (you know like 14.4V). Im not sure if the dead battery is affects his reading or not so im gonna go pick up another battery tomorrow and have them test the alt again after the battery is installed.
Now on to my real question. I've got a 1000W amp and I know the load can get a little much on the alt so if it is bad I would like to use this time to upgrade to a alternator with more output. I saw the thread about the gm alternator but didnt see what vehicles it came out of or where to get one.
My real question is, what higher output alternators will fit an 02 tacoma 3.4?
The cheaper the better as always but i wouldnt want to sacrifice quality.
Thanks
Sam
Old 07-13-2006, 03:18 PM
Good Times's Avatar
you check out this thread?
https://www.yotatech.com/forums/show...+gm+alternator
Old 07-13-2006, 04:44 PM
Firefightertaco's Avatar
You can test you old alt. by turning the truck on and putting a screw driver or something metal up the the middle of the alt. pully and if it pulls the screwdriver like a magnet then it is still good but if not then your alt. is bad.
Old 07-13-2006, 05:36 PM
ssbogger's Avatar
Yeh i did the test where you pull the positive wire off the battery and it still ran. I guess I'll look into some sort of GM alt. Still not sure on what all needs to be modified to make it work. Ideally I would get a bolt on application that i could do in 30 min. Hassel free.
Old 07-13-2006, 05:40 PM
MTL_4runner's Avatar
That just tells you if the field is working or not, but other things can be bad on an alternator as well such as the voltage regulator, etc. Voltage under load is the only true test for an alternator. A dead or dying battery is the #1 cause of alternator failure in lower mileage alternators as well.
Old 07-14-2006, 12:58 PM
ssbogger's Avatar
i got the battery switched out and the alt tested good after that. It was reading around 14v at idle.
shooter86314
01-07-2016 07:05 AM
Chicken12
10-14-2015 03:54 PM
fountain
09-28-2015 03:04 AM
SCZIG
09-20-2015 09:00 AM
scheuvront1993
09-17-2015 06:17 PM
Quick Reply: Alternator going bad...
