Aloha Bruddahs! MissFire P305
Sup Guys, here on maui with one poor running Tacoma
V6 3.4 180k well maintained
2nd T belt @ 118k
Misfires started about two months ago, It actually started on cylinder 3, so I swapped coil packs from cylinder 3 with cylinder 5 and the misfire moved. I thought, great, that was easy, just a bad coil pack. However, now I'm getting misfires from cylinder 5 once again, and it's a brand new coil pack OEM.
The misfire has remained on cylinder 5, never returned to cylinder 3. for two months and around 600 miles.
Have replaced
plugs with nkgs, dual
plug wires OEM
replaced fuel injector (#5) OEM
Still stumped, anyone have any ideas.
I don't think it's the timing belt, what do you think? bad timing belt should give me multiple cylinder misfires
I'm thinking it's either fuel or spark
I have compression tester on order, got a meter on order, and fuel line pressure gauge.
Shootz, den anybody who uncovers my problem will get some fresh Lilkoi butter
Aloha
2nd T belt @ 118k
Have replaced
plug wires OEM
Aloha
thanks for the reply,
yeah, I thought maybe I screwed things up. I cleared the codes and swaped coilpacs again, still missfires on 5.
I'm waiting on a fuel pressure gauge, just I can rule it out.
Anyone know what I should expect if I open these valves up. should I go ahead and get some shimes? I do have gaskets and washer gromets
Sounds like a tight valve
I would lean towards a burnt or tight valve. Take the valve cover off and check the valve clearance with a set a feeler guage. If the clearence is too tight the valve will not fully seal properly (especially when warm) and will give you an intermitant miss.
You can also do both a dry and wet compression test (poor a little oil in the cylinder for the wet test). If the results are the same on both tests and the compression is low on the cylinder then its a leaky valve. Carbon on the valves from leaky valve stem seals often causes issues with valve clearance and can lead to a burnt valve or a valve that sinks into the seat slightly and looses clearance.
