| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
For all of those with the Power Surging Problem! Interesting Problem Found!
__________________
Just call me TA 2000 Toyota 4runner Limited 3.4l V6 Auto SUPERCHARGED, URD 7th, 2.2 pulley, Doug Thorley Headers - My truck All the Mods that can be done to 3rd Gens Thread My thoughts on Gun control summed up quite nice: “Gun control runs aground on this simple fact: people who would use guns to break laws would also break laws to use guns” |
#2 (permalink) |
Did you check the fluid in your turn signals? Mine was very low once and as soon as I topped it off....no more surging. I used Toyota OEM synthetic turn signal fluid.....
#3 (permalink) | |
Quote:
![]() Back on topic. lol
__________________
#4 (permalink) |
Electrical wiring upgrade...
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks. Be polite. Be professional. But, have a plan to kill everyone you meet. |
#5 (permalink) |
Yeah, but want to tell me how to go about that?
I have a few other eletrical querks that make no senes on mine as well from time to time.
__________________
#6 (permalink) |
Big 3 wire, alt, battery and starter?
__________________
#7 (permalink) |
Yeah, i plan to do that when i install the SC but could that be causing this problem??
__________________
#8 (permalink) |
I've seen some electrical problems appear from the little wire (from the NEG terminal to the inner fender) being broke.
#9 (permalink) |
I know that is not the problem as i already have a beefed up wire there (had some extra when i installed my radio and put it there). But i guess it not be tight or something, i will look at it.
__________________
#10 (permalink) |
i have never noticed surging while driving, but i have at idle. in park, neutral, or drive as the rpms drop lower(to about 5 or 600) it automatically gives it gas and jumps to 1500. I think the ecu is telling it to do so because of power consumption so it raises the rpms to spin the alternator faster....or somethings broken =/
__________________
2000 4Runner Limited V6 Auto... 2wd =[[[ Sony GT510 head unit, Kenwood 1700 watt max mono amp, Two 12 inch Polk Subs in ported box, 3 farad capacitor, neons in front footwells Foglights on bottom of rear bumper Optima Yellowtop, Kc daylighters on front bumper Vortex muffler and Trueflow airfilter |
#11 (permalink) |
Well my idle is fine (a little low but fine).
When looking at my OBD scanner i noticed that my TPS is showing 12% = 15% when my foot is not on it at all, and only goes to a max of 75% when i am down to the floor. Don't know if that is the way it is meant to be or if that could be a problem?
__________________
#12 (permalink) | |
Quote:
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. |
#13 (permalink) |
That would be GREAt, i have a few other problems that could be related to the TPS if it is bad.
__________________
#14 (permalink) |
Mine shows 9% foot off the pedal and a max of 70 something % I think it was at WOT. It was hard to tell because I can't stay at WOT very long in traffic.
__________________
#15 (permalink) | |
Quote:
As for the WOT, i did mine with the engine off, that way i could do it all day and not have a problem lol. Thanks for the info!
__________________
#16 (permalink) | |
Quote:
__________________
#17 (permalink) |
Yep, with the key on and the engine off all the sensors will show up, most are just not working due to the engine not running.
__________________
#18 (permalink) |
Check the grounds on the side of the intake by the diagnostic port. Mine were loose and created the weirdest symptoms then eventually quit running.
__________________
'98 4Runner Limited White w/ silver flares |
#19 (permalink) |
I don't remember any ground on the intake? Where exactly is this?
__________________
#20 (permalink) |
On the driver side there is a diagnostic port bolted to the side of the upper intake. There are 3 or 4 wires bolted right by that box tot he side of the intake plenum
__________________
#21 (permalink) |
probably all those lights and accessories sucking the life out of your truck
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler. Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall! It's a Jaap thing....You wouldnt understand |
#22 (permalink) | |
Quote:
LOL, well it did it before those and actually i have not used any of those lights in months due to my alternotor going out and my voltage dropping if i even turn on the stock fogs. But those would not cause any problem with the stock stuff as they are wired totally indepentdent and have not even been used.
__________________
#23 (permalink) |
Check all your engine ground wires. Disconnect, clean & reconnect them.
Paul
__________________
Gone, but not forgotten: 1996 4X4 4Runner LTD. Purchased used 5-08, 120K. Now has 265/75 16 Terra Grapplers, Performance Products springs, Bilsteins. Cupholder Mod. 2001 Tundra, V8, 4x4, Xtra cab, Limited, TRD Offroad. PP springs, Bilsteins, Snugtop shell. Owned 0-112k mi. 1992 4Runner, V6, 4x4, 5spd, SR5, PP springs, Bilsteins. Owned 0-219k mi. 1988 Pickup Xtra cab, I4, 4x4, 5spd, SR5, Ranchos, rear shackles, shell. Owned 0-122k mi. |
#24 (permalink) |
TA maybe you don't need to install that supercharger after all, you can just use your turn signals for that extra boost.
__________________
2004 Tacoma Xtra Cab/PreRunner/SR5/TRD 1998 4Runner Limited |
#25 (permalink) |
LOL, i wish. Though I can't figure out how the engine RPM goes up and my speed stays the same when it is surging.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 22re surging problem SOLVED! | Junkers88 | 86-95 Trucks & 4Runners | 8 | 03-14-2008 06:30 AM |
| Lost power, found problem | shiftless89 | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 06-06-2005 07:38 AM |
| Interesting Electrical problem | NorCalVP | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 09-18-2004 06:24 PM |
| Interesting A/C problem/observance... | rpeAMP | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 02-27-2004 09:41 PM |
| 3rd gen with surging problem | kimchee | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 12-05-2003 04:31 PM |
