All Range E-locker HELP?
Old 11-13-2004, 02:22 PM
Stump1883's Avatar
It's not often that I don't understand what is going on with my 4Runner, I haven't posted in the general tech forum in a loooooong time, but I'm loast on this one. I was trying to wire my e-locker to be range(2WD, 4 HI, and 4 LOW). I followed the write up in the tech section, I cut and grounded the blue an red wire 3rd from the left on the bottom row, blah blah blah. It's the right wire trust me.
The problem comes here, grounding that wire engauges my 4WD and it won't let go of the front diff until I unground the wire. I ahve the push botton type 4WD that came on LTDs. So in 2WD with the botton no engauged, once I ground the wire the 4WD engauges, and won't disengauge until I undo the ground. The locker is not being effected at all by this wire, it will still engauge in 4LOW like usuall, but 4HI will not let go. What is going on here, is there something different when you have the push botton type 4WD, or am I just screwing this thing up big time?
ANY INPUT IS WELCOME. Pictures would be great, suggestions, something. Let me hear it all, it might get my wheels turning. If there is someone out there with a FSM for 96-02 Runners, my rig is a 97 LTD 4WD with pust botton 4HI. Look up the wiring diagram for me and see what it says about the e-locker wiring.
Thanks in advance.
-Scott
Old 02-15-2005, 08:36 PM
dub_valley's Avatar
I am having the same issue, what can I do? any input would great
Thanks
Old 02-15-2005, 08:42 PM
Jared Ajlouny's Avatar
you are grounding the wrong wire...leave the wire disconncted and try to put it in 4WD...if it doesnt engage that means you have the 4WD wire....hope that helps...
Old 02-15-2005, 08:44 PM
TacomaTRD's Avatar
I have a 98 Taco TRD, the wire that I grounded was "gray" for "gray wire mod" I hit it right the first time, mine is NOT push button.
Old 02-15-2005, 09:38 PM
Stegall984R's Avatar
Location: OmG, Hi2U !!! .... DANG, my chic's got some SEXY eyes.... among other things. WOOT WOOT !!
mines push button........... i never had any problem grounding it out. I'll look at mine tomorrow in the light and let you know.
Old 02-17-2005, 04:32 PM
dub_valley's Avatar
Well , I finally got it to work for me. I had a bad connection with one of the exsisting connections in the harness. Now it seems work great.
Old 02-18-2005, 07:45 AM
ewarnerusa's Avatar
mine was a gray wire, works great.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
JookUpVandetti
09-30-2015 08:58 AM
sonorn67
09-19-2015 05:39 PM
Patrick1976
09-15-2015 11:33 PM
zz_denis
09-06-2015 03:43 PM
Quick Reply: All Range E-locker HELP?
