alignment question
Old 04-09-2007, 09:28 AM
zberch's Avatar
alignment question
will changing my struts mean i need to get new alignment?
Old 04-09-2007, 09:30 AM
BajaRunner's Avatar
Yep...
Old 04-09-2007, 10:08 AM
MTL_4runner's Avatar
No, you don't need an alignment when changing shocks.
I think SC4runner just misread the question.
Old 04-09-2007, 10:48 AM
zberch's Avatar
Sure about this? Sounds right to me but dont you have to disconnect the sway bar and stuff that doesnt do anything to alignment?
Old 04-09-2007, 10:55 AM
eric-the-red's Avatar
The sway bar doesn't affect alignment, and as long as the new struts are the same length as the old ones there should be no change. If you are changing to OMEs or Tundra coils then yes the alignment will need done.
Old 04-09-2007, 11:13 AM
BajaRunner's Avatar
I always think struts = coils+shock.
If your just changing the shocks, then no, if the coils are being changed, yes.
Old 04-09-2007, 12:18 PM
Yes, as a former pro mechanic I am positive.
Old 04-09-2007, 12:40 PM
zberch's Avatar
Thanks!
Im running the OEM toyota struts up front with OME coils.
Are OME struts and/or bilsteins the same length?
Old 04-09-2007, 02:00 PM
Thanks!
Ok, hold the phone, I said no alignment needed if you change the shocks. If you are changing springs, you absolutely need an alignment because it will likely change the ride height and effect the alignment settings. If you are indeed changing both shocks and springs then SC4runner was completely correct in his original answer and it was I that misread the question. The term "strut" is often misused so it may mean just the shock or shock + spring system together.
Old 04-09-2007, 02:43 PM
zberch's Avatar
3rd gen runners have struts in the front and shock in the back. I already have the coils front and rear on but have put new struts in the front yet.
Old 04-09-2007, 04:12 PM
3rd gen runners have struts in the front and shock in the back. I already have the coils front and rear on, but have to put new struts in the front yet.
So we'll assume that when you say strut, you're only talking about the shock portion only. I wanted to be very clear so that something wasn't lost in the semantics of what was said. It just threw me off a bit when you started talking about spring replacement too.
Ernie217
08-14-2015 05:25 AM
Up&Down
08-05-2015 06:20 AM
makemusic116
08-02-2015 05:23 PM
makemusic116
08-02-2015 04:40 AM
hangtown88toy
07-10-2015 02:33 PM
Quick Reply: alignment question
