Aisin who can tell me what these parts are
Old 01-16-2005, 10:00 PM
johnnyutah36's Avatar
OK I got some Aisin hubs off ebay to do the ADD to Manual conversion. I got the hubs all cleaned up and painted just need to get new gaskets and then they are going on.
MY QUESTION
These parts were in with the hubs nuts and bolts I am not sure what they are used for or if I need them. The hubs appear to have all the parts from that PDF file that is all over the place. They also seem to function properly. Can anyone tell me what these parts are used for???
Old 01-16-2005, 10:18 PM
jimbo74's Avatar
the splined washer goes around the axle shaft itself.. there is a recess for the big clip in that same area.... its hard to explain without being htere.. i know exactly what those parts are
Old 01-16-2005, 10:41 PM
so do they go on before the hub? Like I pop off the ADD hub then put those parts on then the new hubs?
Old 01-16-2005, 10:42 PM
jimbo74's Avatar
its hard to explain..
Old 01-16-2005, 11:16 PM
ok can anyone explain or know where I can view pics of those installed. I do not see them on any of the posts for doing this upgrade
Old 01-16-2005, 11:38 PM
AW1090's Avatar
If I'm not wrong aren't those just extra? I don't think you need them as long as you've got the snap ring that goes on the back of the hub body. As far as I can remember that snap ring and one other on the inside of the dial were the only two snap rings in the hubs. If you've got those two already in place then you shouldn't need the parts pictured.
Old 01-17-2005, 03:24 AM
boyzWidToyz's Avatar
those are for a solid front axle toyota 4x4.
Install the hub housing. but not the cap.
You should see the axle stub sticking through the middle of the hub. It should have a little play in and out. You put the washer over the end of the stub axle. The c clip thing goes in the groove to keep it from pulling too far out (towards the center of the truck)
IFS trucks use a large washer and bolt that go into the stub.
Old 01-17-2005, 03:45 AM
PirateFins's Avatar
Those are the snap rings and washers to hold the axel in place in the hubs, for trucks that are equiped that way. My truck in the Haynes manual is supposed to have them, but I have a bolt and washer that goes into the end of the axel and holds it on.
What year is yours? and did your ADD have the bolt an washer in the end of the axel. If so then those parts aren't needed.
Old 01-17-2005, 03:57 AM
Ilovemountains's Avatar
Exclamation Here is a pic with the hub off.
I just changed my wheel bearings out and luckily took a few pics! This is a shot of the axle with the hub pulled off. The washer slides over the spline which is attached to the CV joint, then the clip goes over and keeps it all from pushing back through. http://pg.photos.yahoo.com/ph/saabbo...07.jpg&.src=ph
Old 01-17-2005, 04:01 AM
Exclamation you should have this also!
My rig has the bolt/washer also. You have to take it out in order to get the lock portion of the hub off. I used my Hendrix motorsports hub puller that I later found of was really made for solid axles to pull my manual hubs. When I started to crank on it the snap ring popped and the CV started pushing in rather than the hub pulling off. I called Hendrix to ask WTF? They told me that is a problem and that they need to put that info on the web site that they were sorry! I used the hub puller to beat my hubs off which worked OK!
Old 01-17-2005, 08:33 AM
LoL Glad to hear your Hub puller doubles as a BFH. You should call them back and tell them too put that info on there website!!!!
OK so what I am getting is that those parts are used in Solid Axle setups correct? After reading the replies I immediatly went and checked the Spline count on the hubs thinking they were for Solid Axle but there are 26 splines so I got the correct hub. Sweet I think I am set then. Thanks for all the quick replies you guys rock!!!!
09-04-2015 09:27 AM
88sasturbotoy
08-11-2015 01:56 AM
sojourner567
07-16-2015 08:52 PM
Fundy Rider
07-16-2015 01:35 AM
akaphilly
07-09-2015 02:34 PM
Quick Reply: Aisin who can tell me what these parts are
